Sponsored by: Real Truck
Radio stays on
Old Mar 20, 2020 | 10:46 AM
Tsberg2003250's Avatar
Tsberg2003250
Radio stays on
2003 f250 I just bypassed the door ajar switch on both doors because they were draining my battery now my radio is staying on after I shut off the ignition is there anything I can do thanks
Old Mar 20, 2020 | 06:24 PM
Djosbun's Avatar
Djosbun
Yes, the fix is to resolve the door switch issue (which is either a bad switch or a broken wire). Or you can add a toggle switch to the radio power wire and turn it off that way, which would be a poor idea.
-- Dave
Old Mar 20, 2020 | 08:42 PM
jmtbiggin's Avatar
jmtbiggin
Possible bad power delay relay.
Old Mar 21, 2020 | 08:12 AM
projectSHO89's Avatar
projectSHO89
-- Dave
What he said. ^^^
The way it's "supposed" to work is that the Accessory Delay Relay remains on, powering the radio and the power windows, until either a door opening is detected or the accessory relay delay timer expires (~40 10 minutes). { edited }
Your 'fix" circumvented the trigger to turn off the accessories.
Old Mar 21, 2020 | 10:04 AM
Tsberg2003250
Thanks guys I suppose the way to fix it is do it the right way was dreading it tight squeeze thanks again
Old Mar 22, 2020 | 08:16 AM
alloro's Avatar
alloro
The radio and power windows are powered by the accessory delay relay for 10-minutes after the key is turned off or until a door is opened, whichever comes first. The battery saver relay turns the interior lights off 40-minutes after a door is left open. So you can either fix the door switches, manually turn the radio off, or just leave it and it will turn off in 10-minutes all on it's own.
Old Mar 22, 2020 | 08:19 AM
Tumbleweed1972's Avatar
Tumbleweed1972
I agree with the rest although I don't think that it is 40 minutes. I think it's ten. The door switch went out of my 02 and it just became a habit to reach over and flick the radio off as I turned the key off. The lights underneath the window switches would stay lit up though for a short while afterwards though.
Old Mar 22, 2020 | 09:22 AM
projectSHO89
Yep, ten minutes is correct for the ADR. Edited above.
Good catch! Thanks, guys!
Old Mar 23, 2020 | 03:20 PM
D.Yaros's Avatar
D.Yaros
Dumb question here, but would not turning off the radio before turning off the truck cut off the power to it notwithstanding the door ajar switch?
Old Apr 5, 2020 | 08:34 AM
Tumbleweed1972
I don't think that I follow what you are saying. The radio stays on after the key is turned off until the door is opened, if the door switch isn't functioning then the radio doesn't get a signal to turn off, turning off the key doesn't make the buttons on the radio quit working so even after the key is off you can turn the radio on or off until either ten minutes has gone by or a door has been opened.
cdestuck
2015 - 2020 F150
Apr 6, 2020 05:10 PM
Highboosted
May 10, 2019 11:17 PM
brookingsford
1997 - 2003 F150
Dec 29, 2014 08:10 PM
Map Man 1
6.7L Power Stroke Diesel
Jun 20, 2014 01:39 PM
UawMan
2004 - 2008 F150
Dec 25, 2006 12:15 PM
