Coolant leak
Old Mar 20, 2020 | 01:53 AM
FrankNBeans's Avatar
FrankNBeans
Coolant leak
I am the original owner of my 2005 F350 6.0. It’s stock. I have a coolant leak at the passenger side rear of the engine. Originally I thought it was the water pump but it’s definitely leaking at the rear of the engine on the passenger side. Could it be from the HVAC/heating plumbing. Not a lot of room to see where the leak is coming from. 173,000 on the truck
Old Mar 20, 2020 | 03:42 AM
Yahiko's Avatar
Yahiko
Get some UV cooling system dye and put it in and run for a bit. Then check with a UV flashlight (black light).
I have found that it takes two bottles of the stuff.
Do you have an EGR deletes? If yes check around the hoses.
Old Mar 20, 2020 | 03:46 AM
FrankNBeans
No egr delete. I will definitely look into the UV dye.
Old Mar 20, 2020 | 04:39 AM
Visurveyor's Avatar
Visurveyor
If no egr delete, check you little blue tube coming off your oil cooler to your egr cooler. They are known to leak and flow down the valley and drop down above your starter.
Old Mar 20, 2020 | 07:45 AM
SmackDaddy's Avatar
SmackDaddy
Check the heater core y pipe and quick connect fittings that go into the heater core at the firewall above the AC box. Pretty common, there is a thread with a replacement solution for the plastic y pipe and heater core connections.
Old Mar 20, 2020 | 07:47 AM
SmackDaddy's Avatar
SmackDaddy
Do the trucks not have the y pipe and just inlet and outlet above the box? Excursions have the y pipe because there is a second heater core in the rear. I would still check those heater core quick connects, the o rings inside can leak, mine both started leaking around 170k.
Old Mar 20, 2020 | 11:58 AM
Yahiko's Avatar
Yahiko
You are correct.
If you have a coolant filter also check the hoses and connections.
That was one of my leaks.
Old Mar 20, 2020 | 12:12 PM
Visurveyor's Avatar
Visurveyor
That is another good point. I have a coolant filter that one hose leaks.
I been lazy. But that would show up on the front of the motor or quick inspection.
It's them sneaky leaks, where there not sure.
ftv37
Aerostar
Sep 3, 2015 07:09 PM
Windsetter
Aerostar
18
Nov 21, 2010 03:29 PM
98FordTruck
1997 - 2003 F150
Jan 14, 2009 09:13 AM
