Sponsored by: Real Truck
Extra fuel tank
Old Mar 18, 2020 | 01:35 PM
mtnsammy's Avatar
mtnsammy
Extra fuel tank
I am considering adding a second fuel tank. A lot use the after market but I was thinking placing it where the spare tire is. My last truck was an Excursion and the truck equivalent could use both a spare tire tank and a saddle tank along frame rails. Just curious if anyone has done this too?
My hope is to add a box under flat bed with an RV Fuel station to it. Then we could fill the mowers and tractors off the truck tank and avoid the mess of 5 gallon tanks. When traveling it would also double our fuel capacity. It would be nice to run dual tank setup if possible.
Part numbers or retailer information would be nice from those that have done this already. If it becomes too much I will just put a box tank on top of the flat bed. I would rather keep the entire bed open for cargo.
Old Mar 18, 2020 | 01:54 PM
WE3ZS's Avatar
WE3ZS
I don't think new OEM EXcursion tanks (and skid plates) are still available, best bet would be to find an EX in a parts yard and use that. It has been done and shown here at some point, I remember a few threads on the subject. You may need to fabricate a new frame crossmember or two to have something robust enough to mount the 4 skid plate bolts to. The extra 44 gallons will be nice to have.
Old Mar 18, 2020 | 02:03 PM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
Look at a fuel tank for a cab chassis, they mount it behind the axle from the factory.
Denny
Old Mar 18, 2020 | 03:17 PM
mtnsammy's Avatar
mtnsammy
RVPuller that is what I thought too. I will be heading to the yards this weekend if it ever stops raining.
WE3ZS nice Excursion in your photo. I had an 01 Excursion with the 7.3. The fuel tanks were interchangeable in those years but I was looking for any options like cab chassis tanks and such. On guy locally welds up tanks and said he could make one that drops down from the top and sits on the frame rails. Not sure yet how much fuel I would get and If I could still hook it up in union with the existing tank. I guess the dual tanks are a thing of the past.
Old Mar 18, 2020 | 05:48 PM
Just Strokin's Avatar
Just Strokin
Must of the brackets from the chassis/cab might not work. The c/c frame is 34" wide and the pu is 37.5" wide.
TampaDave
6.7L Power Stroke Diesel
Feb 5, 2015 11:48 AM
Number21
Oct 18, 2013 06:40 PM
Biodiesel Boy
Jun 2, 2011 09:07 PM
bigbubba87
May 25, 2010 12:25 PM
bkks744
Sep 1, 2007 01:09 AM
