1997 F250 HD, Cant find tierods TTB 50
My truck is lifted, not sure the size, but clears 37" tires. the tierods are longer than the factory ones & bolt up completely diffrent. can someone tell me what this is attatched to my pitman arm i believe. & also, i changed my front en parts, (ball joints, wheel bearings,) and i still have negitive camber a the tires lean in at the top, i this normal? i know its always done it but thaught this would help.
Do they drop the TTB enough for your tires and total lift? 37s are pretty tall. Maybe a PO added different leaves, add-a-leaf, or the leaf bushings are roached?
Check out those caster/camber keys too. You need a boss alignment guy to get a TTB truck to drive correct. I have one in DFW and one in Houston if that helps.
tlapham
19
08-08-2012 04:22 PM
lud04X
02-22-2008 02:00 AM
