Possible cold start upgrade?
Old Mar 19, 2020 | 08:55 AM
tecgod13's Avatar
tecgod13
Originally Posted by RaymondIV
What engines had that, never heard of it? Quite a few diesels came out factory equipped with an ether injection system but no fireball involved, just a shot of metered ether mist into the intake system.
The oil truck I drive for work has one. Not entirely sure how it works, but the manual says its a flame start system. Its a 6 cylinder Cummins in a 95 Kenworth T300. Its been a while since I looked closely at it, but I remember something that looked like and injector or two in the intake. I don't know how the fuel is pumped in, or what ignites it. There is a 'don't start' light like our trucks that comes on with the key. On cold days when the block heater outlet either wasn't plugged in, or the outlet tripped the flame start will run for quite a while, maybe 20+ seconds? But it fires to life everytime!
Old Mar 19, 2020 | 11:59 AM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
Originally Posted by Traven Friend
wouldn't it get past the intake valves during the intake stroke? Pretty sure it would. Also i agree with a compression release however i would just treat it like waste boost and put an automated pressure release valve on the intake manifold to despurse any unwanted pressure that could cause cracked heads or bent valves... I would defiantly like to see a 24V mod with a 4 battery set up as I'm trying to have mobile MIG Welding.
you can do some pretty good welding with a Lestek unit even certified for Marine and Aircraft... don't need 4 Batteries....
I'm waiting for the price of Ultra Caps to come down a bit too and plan on using a bank for starting... you could start even with pretty Flat batteries.
I'll be using 12 volts of the 24V Glow plugs .... I'm doing this mostly as an experiment in GP longevity as in South TX we don't need to super heat to start these trucks
I've worked on the 19L v12 air cooled engines myself non turbo... but we did have access to a couple of the V12 Bi-Turbo engines too along with the MTU engines.
and yeah, I guess while Cranking IF you injected Flame it would heat the cylinders BUT I think this would be better suited for larger DI type engines and not real good on a 6.9 or 7.3 ... they are already easy to do Either or propane systems.
Old Mar 19, 2020 | 12:14 PM
RaymondIV's Avatar
RaymondIV
[QUOTE] Its a 6 cylinder Cummins in a 95 Kenworth T300.[/QUOTE]
I'll be darned, interesting, I used to work on Cummins during that era, but never ran into any with the flame start system, just the normal ether system. I Googled it and it says it's not real common but there's versions for everything from small car diesels to big truck engines.
wicks302
Nov 10, 2012 04:42 PM
d90000
6.7L Power Stroke Diesel
Dec 25, 2010 07:02 PM
A H DEVELOPMENT
Jan 8, 2010 04:49 PM
Fordenthusiasts
Mar 1, 2008 01:18 PM
61 uni
Aug 17, 2007 12:23 PM
