Steering Fluid Leak
Old Mar 16, 2020 | 03:28 PM
L-ight's Avatar
L-ight
Steering Fluid Leak
So I noticed I had two small puddles of PSF (really trans fluid) on the ground near the front of the truck. I go to look and see a small drip area on the bottom side of the steering box. So i look on then look on the top side of the steering box and notice a small amount of puddled fluid there as well. I look around some more and notice another small drip area on the bottom side of the reservoir. I checked the hose that attaches to the bottom of steering pump reservoir and it was nice and tight. The truck has 111k miles. 2003. No trans cooler leak either. Checked near the cooler and it was dry. Could it be a power steering hose?
Old Mar 16, 2020 | 04:43 PM
afonda's Avatar
afonda
prob a bad hose or bad steering pump... have you changed out the pump recently?
Old Mar 16, 2020 | 08:38 PM
L-ight's Avatar
L-ight
Pump is original. I have flushed it several times though.
Old Mar 17, 2020 | 05:30 AM
FordTruckNoob's Avatar
FordTruckNoob
Is the reservoir overfilled?
Old Mar 17, 2020 | 06:45 AM
L-ight's Avatar
L-ight
No. I flushed it back in mid November/early December and have had zero problems.
Critterhunter
1983 - 2012 Ranger & B-Series
Jul 24, 2020 10:25 AM
gumbydamit
Nov 27, 2006 08:59 PM
fmc400
Dec 22, 2005 07:42 PM
