Door dissasembly
Old Mar 14, 2020 | 02:53 PM
Loosescrews's Avatar
Loosescrews
Door dissasembly
Can anyone point me towards a video or article/post about door linkage dissasembly/assembly. Getting doors stripped down to sandblast and paint. Have everything removed except door handle lock linkage and a little unsure. Don’t want to break stuff. Thanks. 1978 F250
Old Mar 14, 2020 | 03:02 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Ck out this guy, maybe he covers it in his door seal video? https://www.ford-trucks.com/forums/1...-series-2.html
You know the door lock key assembly is held in place by a slide tab. Go to the edge of the door, look for a 90* tab and just pull it. It's that simple. As far as the linkage most connections are held together by the plastic flip tab, like used on the tailgate rods. Un flip and remove rod end.
Old Mar 14, 2020 | 03:04 PM
Loosescrews
Thanks. I figured it out and nothing broken.
Old Mar 14, 2020 | 03:25 PM
Loosescrews
Completely different question. How do you get the vent window out of the frame?
Old Mar 14, 2020 | 03:33 PM
77&79F250's Avatar
77&79F250
Look at the angled front edge of the door 3 phillips head screws. Remove. One bolt (below the regulator) that holds the very bottom of the division bar in place. Remove. Angle the vent window (it will be one piece) and the glass and the long division bar. You might have to work out/wiggle around the bracket at the very bottom of the division bar to get it out between the door skins.
Old Mar 14, 2020 | 04:03 PM
Loosescrews
Trying to get the glass out of the frame. Already pulled the assembly.
Old Mar 14, 2020 | 04:21 PM
77&79F250's Avatar
77&79F250
Well it is held in with "glass setting tape". Here is a thread on removing and replacing the glass.
https://www.ford-trucks.com/forums/1...storation.html
In the above thread post #110 talks about removal and 115 and 132 about installation.
Old Mar 14, 2020 | 04:25 PM
Loosescrews
Thanks a lot. Really appreciate the help.
Old Mar 14, 2020 | 04:55 PM
72rtchallenger's Avatar
72rtchallenger
Heat gun will help,,I replaced mine , its not to bad and you can buy the glass tape needed for replacement
Old Mar 14, 2020 | 07:08 PM
i61164's Avatar
i61164
If you mean remove the vent window glass out of it’s frame, I just did that. I boiled water in a 7 quart Dutch oven and dipped the window and frame in until the adhesive softened enough for me to pry the glass out. I wore gloves to handle the hot window/frame.
bjarnold1
Feb 9, 2019 05:45 PM
IowaJack
2009 - 2014 F150
Dec 27, 2014 04:42 PM
1998F250SC
1997 - 2003 F150
Oct 25, 2009 10:50 AM
acemav52002
Sep 9, 2009 11:09 PM
metlchip
Jun 27, 2003 07:09 AM
