Turn signal indicator blinking fast
that plug is going to make me run face first into a cactus! Causes BLIS warning, Cross Traffic Warning…luckily, no other issues like others have noted. I just get tired of clearing the dash every time I start the truck,
Hyper flashing dash signals
My turn signal indicator in the instrument cluster started flashing fast today for no apparent reason. All turn signals are flashing at the correct speed but the indicator is flashing fast. To make it even stranger, it will correct itself if the truck is turned off but acc mode is on but as soon as the vehicle is started, it starts flashing fast again.
Anyone ever experienced this or have any ideas as to what is wrong?
Truck is a 2017 F250 Platinum (all LED) with stock lighting.
My turn signals were hyper flashing on the dash and I tried some remedies on this thread to no avail. Then I started getting messages on my truck for low battery power. One morning it was completely dead. I replaced my battery a lo and behold my dash indicators were flashing a normal rate along with the front and taillights. Could be that your battery needs replacing. It worked for me.
OK, this is crazy. Earlier I disconnected the positive side of the battery and that did not correct the blinker indicator. Just now, after cleaning a bunch of the connectors with no impact, I disconnected the negative side of the battery and guess what? It is not corrected!
What possible difference can it make between the positive side and the negative side? Obviously, some difference because now it is working.
Same Issue
Well my 2020 SD did the same thing on the left turn signal. Took the dealer a month. Replaced lighting control module, replaced all bulbs, replaced several sections of wire harness, did a few overlays around the wiring harnesss and reprogrammed a control module. Finally fixed it. Now at 35k and the right blinker now doing same thing! QUOTE=copper1977;19171169]My turn signal indicator in the instrument cluster started flashing fast today for no apparent reason. All turn signals are flashing at the correct speed but the indicator is flashing fast. To make it even stranger, it will correct itself if the truck is turned off but acc mode is on but as soon as the vehicle is started, it starts flashing fast again.
I have the same exact thing happening with my right now. It's a '21 F350 Plat.
Out of the blue, indicator started flashing fast, all signals and lights are working and when truck is turned off and acc mode is on, it flashes normally. I've had it twice where the indicator was flashing normally for a day, and then went back to flashing fast.
Anyone have a solution??
bcaughhorn
13
Dec 13, 2010 06:16 AM
afonda
22
Dec 20, 2008 01:47 PM
00Expo&73Bronco
Jul 18, 2003 08:55 PM
