Codes 332 and 335 ...Suggestions?
Old Mar 16, 2020 | 12:03 AM
Dan P's Avatar
Dan P
Originally Posted by matt167
You will find that some ( a lot ) of stuff for the OBS Fords are not cataloged correctly due to skewed numbers in aftermarket parts books. But I do believe all of the DPFE sensors are electrically the same.
agree...had to slightly modify the plug and the sensor, but it plugged in and seems to be working fine so far.
Old Mar 16, 2020 | 09:52 AM
restoman92's Avatar
restoman92
DPFE Sensor
Aftermarket sensors are bad for changing wiring recepticles. They use the best sellers. They are very bad, even OEM, for moisture inside. If vehicle sets, moisture in exhaust collects. Very common problem.
Old Mar 24, 2020 | 02:31 AM
Aapple416's Avatar
Aapple416
Check all the vacuum lines from EGR. Vacuum tree. They should all be color coded
Mine wasn't running the best. Slight miss, idled wired, seemed almost like it need more fuel some times, went to check them last night an they were all dry rotted. I barley would move them an they snapped like a twig replaced them all an runs great now. An this was on a 95 f150 with a 5.0
^ this is a 92 diagram but used it to help me
Old Mar 24, 2020 | 09:02 AM
torq'ta 5 8's Avatar
torq'ta 5 8
check under your hood, for sticker like above, if its gone, just fix one line at a time, most are 5/32
93 F150 351w vacuum line replacement - Ford Truck Enthusiasts Forums
Old Mar 24, 2020 | 09:49 AM
Dan P's Avatar
Dan P
Thanks, but simply changing the sensor (after slight modifications) seemed to cure all ills. No more CEL, no codes, and she's running perfect.
Dan
Old Mar 24, 2020 | 03:49 PM
torq'ta 5 8
good to hear, but you'll need that sooner or later,
Old Mar 24, 2020 | 10:35 PM
Dan P's Avatar
Dan P
lol😂! Yeah, I know. Thanks for the help!
90sKid90sTruck
Oct 20, 2017 07:42 PM
94wyatt95
Aug 6, 2014 09:32 PM
NW 150
Aug 23, 2013 06:55 AM
steve100
Mar 2, 2007 06:01 PM
f1001978
1978 - 1996 Big Bronco
Aug 25, 2004 07:12 AM
