Three codes showing up.
Old Aug 21, 2013 | 05:54 PM
NW 150's Avatar
NW 150
I have a 1996 F150 4x4 with the 300. Getting three codes in this order: 411, 401, 420. Need ideas on what exactly to check, how to check it, etc. I'm tired of the check engine light coming on. Any help would be great!
Old Aug 21, 2013 | 06:30 PM
rla2005's Avatar
rla2005
A 1996 F150 should display Pxxxx OBD-II codes. Are we to assume those codes are P0411, P0401 and P0420?
Old Aug 23, 2013 | 04:42 AM
NW 150's Avatar
NW 150
Yea it's just how they are displayed on my scanners.
Old Aug 23, 2013 | 04:50 AM
Krisverde's Avatar
Krisverde
IIRC the common issue for a p0420 code is usually a failing cat causing the rear 02 to not function properly
For the p0401 and 411 I'd look for vacuum leaks.
Old Aug 23, 2013 | 06:55 AM
rla2005's Avatar
rla2005
PO401 is a CM only code:
Diagnostic Trouble Code (DTC) P0401 indicates that Continuous Memory Self-Test has detected insufficient EGR flow.
Possible causes:
-- EGR valve stuck closed or iced.
-- EGR valve diaphragm leaks.
-- EGR valve or flow path restricted.
-- EGR vacuum hose off, plugged or leaks.
-- VPWR circuit open to EGR Vacuum Regulator (EGR V.R.) solenoid.
-- EVR circuit to PCM open.
-- EVR circuit to PCM shorted to PWR.
-- Differential Pressure Feedback EGR (D.P.F. EGR) sensor pressure hoses both off.
-- D.P.F. EGR sensor pressure hoses reversed.
-- D.P.F. EGR sensor VREF circuit open.
-- Downstream pressure hose off.
-- Downstream pressure hose plugged.
-- Damaged orifice tube assembly.
-- Damaged EGR V.R. solenoid.
-- Damaged D.P.F. EGR sensor.
-- Damaged PCM.
P0411 can be displayed in the KOEO, CM or KOER tests. When was it displayed? The definition is defined as:
DTC P0411 indicates that Secondary Air is not being diverted when requested.
Possible causes:
-- Vacuum hoses damaged.
-- AIRB/AIRD valve inoperative.
-- Air Pump inoperative.
-- AIRB/AIRD solenoids damaged.
l Visually inspect vacuum lines for disconnects in the AIR system.
l Visually inspect for proper vacuum line routing. Refer to VECI decal.
l Visually inspect Air Pump for broken or loose Air Pump Belt.
Code P0420 is a CM only code:
Diagnostic Trouble Codes (DTC) P0420 and P0421 indicate that bank 1 catalyst system efficiency is below the acceptable threshold.
Possible causes:
-- Use of leaded fuel.
-- Oil contamination.
-- Cylinder misfiring.
-- Damaged HO2S.
-- Damaged ECT sensor.
-- Downstream HO2S wires improperly connected.
-- Fuel pressure too high.
-- Damaged exhaust system pipe.
-- Damaged exhaust manifold.
-- Damaged muffler/tail-pipe assembly.
-- Damaged catalytic converter.
gtex
Aug 19, 2018 07:40 AM
Garym
1997 - 2003 F150
Oct 1, 2007 09:30 AM
strokeman
Aug 27, 2003 10:36 AM
steve83
Nov 6, 2002 04:50 PM
