2019 Transmission Temps
Old Mar 13, 2020 | 06:44 PM
Gary F's Avatar
Gary F
Curious what other are seeing for Trans Temps. My truck is 2019 CC F350 Dually 6.7 with 4:10 rear axle.
Running empty I see 205 to 207 temps however when idling i see 196 to 198.
This is my third Super Duty and my 2013 Dually ran a little less.
Thanks
Old Mar 13, 2020 | 06:47 PM
MrOneEyedBoh's Avatar
MrOneEyedBoh
Its around 200 deg. for me unloaded on the highway.
Old Mar 13, 2020 | 07:33 PM
DADDYFIGJAM's Avatar
DADDYFIGJAM
I guess I'm going to assume that with the diesel the trans runs hotter. My 2019 f250/cc/sb/4x4 with the 6.2 towing my 13.5k FW, it maxed at 197 going up hills. Cruising it was at 190ish. Not towing it peaks around 160ish?
Old Mar 13, 2020 | 07:35 PM
D3thM3tal's Avatar
D3thM3tal
There is a thermostat in the trans that keeps the fluid up to temp for efficiencies. It's totally normal.
Old Mar 13, 2020 | 08:19 PM
Lamoon78's Avatar
Lamoon78
My F350 6.2 pulling usually runs 195-200
Old Mar 13, 2020 | 09:00 PM
Mkos1980's Avatar
Mkos1980
19 F350 6.2 I'm at 195-204 empty or towing. Highest ever was 211 and that was middle of summer pulling our 30ft travel trailer up the Fancy Gap grade on I77
Old Mar 13, 2020 | 09:37 PM
TCNashville's Avatar
TCNashville
Originally Posted by Gary F
Curious what other are seeing for Trans Temps. My truck is 2019 CC F350 Dually 6.7 with 4:10 rear axle.Running empty I see 205 to 207 temps however when idling i see 196 to 198.Thanks
I believe those are normal operating temps for a 6R140 transmission.
Old Mar 13, 2020 | 09:59 PM
ForCal's Avatar
ForCal
Old Mar 13, 2020 | 10:07 PM
ForCal's Avatar
ForCal
Mine is usually between 194-198, F250 6.7L.
I have a photo of the gauges about 2 hours into an all highway trip, shortly after completing a regen, and the trans temp says 196.
Old Mar 14, 2020 | 06:41 AM
jbjones85's Avatar
jbjones85
201 unloaded on the highway and normally 207-210 loaded on a grade
Old Mar 14, 2020 | 06:46 AM
crewzer's Avatar
crewzer
Our 2019 F350 is equipped with the 6.2 and 6R140. Once warmed up, which can take a while, the AT temp smoothly rises and falls between ~196 and 205 F as the transmission thermostat closes and opens.
HTH,
Jim / crewzer
Old Mar 14, 2020 | 06:56 AM
Sasha4's Avatar
Sasha4
Ive seen up to 216 under load. Stays around 200-205, for most other driving. 19' F-450 6.7 w/ 4.30
Old Mar 14, 2020 | 09:39 AM
Atrrider's Avatar
Atrrider
The F-250 gas has a different trans than the F-250 Diesel and the F350 Gas/Diesel.
Old Mar 14, 2020 | 10:15 AM
crewzer's Avatar
crewzer
Thumbs up
An important distinction.
Thanks,
Jim / crewzer
Old Mar 14, 2020 | 12:59 PM
67L48's Avatar
67L48
This has been covered a lot. Searching will give you lots of other discussions. Temps are higher than many are used to seeing.
My 6R140 sits right at 194 when fully warmed up and no load. Same for the coolant temp. 194 F is apparently the set point. With stop and go traffic, it’s easily at 200 - 205. When towing, it’s in the 210 -220 range. When towing 7,000 lbs going up 7% grades at 10,000’, it can get as high as 230.
All of this is normal. Everything is about 20-30 degrees higher than conventional wisdom from the 1980s, e.g. Most online articles are written around this older expectation and will talk about 170-180 being normal, 215-220 being danger zone, and 230+ being in the “shut it down and let it cool off” zone. None of this is applicable anymore ... not to modern Fords, anyway.
texinwa
Ford Truck Parts for Sale
Feb 14, 2018 03:39 PM
BIGTRUCKBIGRV
Dec 11, 2016 01:30 AM
vid diesel
Feb 25, 2006 01:09 PM
ben towe
Mar 7, 2001 05:23 PM
