Rear bumper
Old Mar 12, 2020 | 07:58 PM
DDB1973's Avatar
DDB1973
Rear bumper
Ok. I have 1 last part to purchase. Rear bumper. Its the contoured bumper. Lmc offers 2. One says 37.5 mount holes the other says 40. Where are they measuring from. The bumper bolts on top of the bumper? Or what?
Old Mar 12, 2020 | 08:14 PM
72rtchallenger's Avatar
72rtchallenger
Numbersdummy can tell you for sure, think its the between frame measurements but cant remember for sure , here is an link that may help https://www.ford-trucks.com/forums/1...79-f250-2.html
Old Mar 12, 2020 | 08:20 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
IMO I'd measured where it matters....at the rear of the frame rails where you are going to bolt the bumper on. Do you have the special...well pretty much impossible to find and purchase (due to NOT being reproduced) mount brackets for said contour bumper?
ND says....D3TZ-17906-B .. Chrome Contour Rear Bumper-Use with 37 1/2" rear frame rails / Reproduced. 1973/79 F100/350 - 1978/79 Bronco.
Old Mar 12, 2020 | 08:21 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
33 1/2" width between the inner frame rails behind the cab:
1965/72 F100/350 // 1973/77 F250 4WD (High Boys) // 1973/79 F350 Cab & Chassis & Regular Cabs on the 140" wheelbase.
37 1/2" width between the inner frame rails behind the cab:
1973/79 F100 2WD/4WD & F250 2WD // 1973/79 F350 except as noted above // 1975/79 F150 2WD/4WD // 1977 F250 4WD from serial number Y20,001 (not a High Boy).
1978/79 F250 4WD // 1979 F350 4WD
Old Mar 13, 2020 | 05:24 PM
72rtchallenger
It appears the 40" you speak of is for a Bronco if this is what your looking at on LMC
49-9542
CHROME REAR BUMPER PREMIUM
36-1/2" MOUNT HOLES STYLESIDE 73-79
49-9544
40" MOUNT HOLES STYLESIDE &
BRONCO 73-79
Old Mar 13, 2020 | 06:56 PM
NumberDummy
No such thing as 40" width between the inner frame rails for any 1973/79 F100/350 & 1978/79 Bronco.
49-9542
49-9544
40" MOUNT HOLES STYLESIDE & BRONCO 73 -79
As usual, LMC hasn't a single clue!
1978/79 Bronco uses a completely different bumper than 1966/77.
1978/79 Bronco uses the same contour rear bumper as 1973/79 F100/350's with 37 1/2" width rear frame rails:
D3TZ-17906-A Chrome & D3TZ-17906-B Painted .. Contour Rear Bumpers
But 1978/79 Bronco's use different bumper brackets than F100/350, because Bronco's have a rear stone deflector that the pickups don't have.
Old Mar 13, 2020 | 10:29 PM
broktruk's Avatar
broktruk
It appears that the measurement is where the bumper bolts go through the bumper and in to the mounting brackets. in the parts description, it tells you which one is for which rig.
DDB1973
13
Apr 23, 2022 11:23 AM
jswartz84
Jan 25, 2018 11:27 PM
78 explorer
Sep 3, 2008 07:12 AM
Tranoham
Mar 3, 2005 04:36 PM
