SYNC 3 Navigation Prompts Volume?
Old Mar 12, 2020 | 11:18 AM
Aftrmidnite's Avatar
Aftrmidnite
How do I adjust just the Navigation Volume? This is for the Bell Tone and the Voice Prompts. I don’t want to adjust the Sirius Audio Volume, along with the Navigation Volume.
Old Mar 12, 2020 | 11:21 AM
Robbgt's Avatar
Robbgt
I believe as a prompt/navigation is playing, you adjust from the volume from the ****.
Not sure there is a place for this in settings.
Old Mar 12, 2020 | 12:54 PM
Kingofwylietx's Avatar
Kingofwylietx
Robbgt is correct. You'll need to adjust the volume while the GPS is speaking. That is very ironic since you can't hear the GPS to know it is speaking!
The easiest way to do it is to set a new destination and begin adjusting the volume immediately. When setting a new route, the GPS automatically begins giving prompts after you hit 'start'.
Old Mar 12, 2020 | 02:10 PM
Aftrmidnite
Thanks to all, I have it adjusted so now I can hear the prompts, I swear the Dealer Fracks with my settings when the truck goes in. I also need to readjust the back-up warning tone, and I will give this method a try. It’s blasting out of the head restraints.
Old Mar 12, 2020 | 04:52 PM
Robbgt's Avatar
Robbgt
If you find a way that works please let me know. From what I've researched there's no way to change the volume of the backup warning tones. I used FORScan to forward all tones to the smaller instrument panel speaker instead of the stereo.
Old Mar 19, 2020 | 08:53 AM
Aftrmidnite
I had to take the Truck back to the Dealer, the rear windows wouldn’t roll all the way down. All doors unlocked, when drivers door was opened. “Yes I know, I can reprogram that myself.” Also Quick up and down was gone on passenger window. They gave me grief about reprogramming it, back like I had it. Also they did not change the backup warning tone, back to the speaker, on the dash, by the steering wheel column. They couldn’t figure out how to do that.
Also to adjust the Navigation Prompts, it appears the Radio needs to be off.
crewzer
Feb 27, 2020 06:10 PM
Josh Evans
Dec 7, 2019 05:31 AM
USSenator
Sep 3, 2017 10:33 PM
mojavearcher
Jan 26, 2017 06:07 AM
'04 PWRSTROKE
Sep 30, 2010 10:58 AM
