Rear Window Molding
Old Mar 9, 2020 | 10:22 PM
440 sixpack's Avatar
440 sixpack
Rear Window Molding
I've been searching for a set of the moldings for the rear window for over a year and I've yet to find a single piece. I know they exist because I've seen 1 pickup with them.
I don't know if I should keep looking , my pickup will be out of the paint shop this summer so I'm about to give up. are they really unobtainium or is this just bad luck and timing ?
Old Mar 9, 2020 | 11:49 PM
broktruk's Avatar
broktruk
The wide exterior molding that goes in the rubber seal?
Old Mar 9, 2020 | 11:59 PM
440 sixpack
Yes, for the back window though not the windsheild. I think it was from 73-76
Old Mar 10, 2020 | 04:44 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by 440 sixpack
Yes, for the back window though not the windshield. I think it was from 73-76.
1973/76, 1977 before serial number O80,001 // 1977 from serial number O80,001, 1978/79 is different.
Old Mar 10, 2020 | 06:27 AM
Mark8man's Avatar
Mark8man
Like This? I am surprised at difficulty in finding and did not suspect it was uncommon. I'll keep an eye out for it. "Guessing" it would not of come on trucks with slider window.
Old Mar 10, 2020 | 08:00 AM
mikeo0o0o0's Avatar
mikeo0o0o0
The wide rear window moulding is two pieces:
RH D3TZ-1042430-A
LH D3TZ-1042431-A
I "think" the correct weatherstrip for the rear window with moulding is:
D3TZ-9942084-B
Old Mar 10, 2020 | 08:48 AM
440 sixpack
The one I have seen looked pretty much the same as the windshield molding. wider and more squared off than the one Mark8man has pictured. or maybe that's it and I'm remembering it wrong.
Old Mar 10, 2020 | 08:52 AM
broktruk's Avatar
broktruk
Ya there was thin inset, the wide like pictured, or nothing. It does bear a strong resemblance to shape of front but is less wide.
Old Mar 10, 2020 | 02:43 PM
NumberDummy
^ 1977 from serial number O80,001 & 1978/79.
D7TZ-1042430-A .. Back Glass one piece Flexible Plastic Chrome Moulding - 143" long / Reproduced
D7TZ-1042436-A .. Center Upper Moulding Joint Clip-Use with the above / Reproduced
D7TZ-1042084-A .. Back Glass Weather Strip - Use with the above / Reproduced
1973/76 and 1977 before serial number O80,001 have right and left stainless steel back glass reveal mouldings.
The weather strip is also different. See post #6.
Old Mar 10, 2020 | 02:48 PM
caravaggio2000's Avatar
caravaggio2000
I have the fat molding in the front and the thin in the back (just like Mark's) on my 73 XLT.
Old Mar 10, 2020 | 02:54 PM
NumberDummy
1973/76 and 1977 before serial number O80,001 have stainless steel windshield reveal mouldings.
1977 from serial number O80,001, 1978/79 have a one piece flexible plastic chrome windshield reveal moulding.
The windshield weather strip is specific to one or the other.
Old Mar 10, 2020 | 07:22 PM
broktruk's Avatar
broktruk
Right. The one pictured is early though. Not late 77-79.
fire3110
51
Dec 2, 2012 12:44 PM
pup55
1978 - 1996 Big Bronco
Jan 13, 2006 10:06 AM
74 F100 351m
Jul 21, 2004 09:31 AM
tgregoire
Jul 15, 2002 04:12 PM
texan_eagle_scout
1997 - 2003 F150
Feb 8, 2002 10:34 PM
