rear window
Old Jul 19, 2004 | 10:50 PM
74 F100 351m's Avatar
74 F100 351m
rear window
Will rear window out of 67-72 work in a 73-79?
Old Jul 19, 2004 | 10:51 PM
whalerron's Avatar
whalerron
No. The 67-72 rear cab window is much smaller than that used in the 73-79 trucks.
- ron
Old Jul 19, 2004 | 10:56 PM
74 F100 351m
Thanks for your knowage.
Old Jul 19, 2004 | 11:13 PM
ivanribic's Avatar
ivanribic
The 67-72 windshields will fit however. If you're looking for a compatible rear window keep in mind that they're the same from 73-96 . . . so if you come across a later model you can still use it.
Old Jul 20, 2004 | 12:54 AM
highboy1975's Avatar
highboy1975
my glass guy told me that the rear windows are the same from 67-96. you just have to get the corresponding gasket for the year. he did say something that they got a little thicker in the early 80s but they still interchange.
Old Jul 20, 2004 | 04:18 AM
fellro86's Avatar
fellro86
the size of the glass/frame are smaller. If you park the two year styles side by side, it'll be obvious. He may ahve looked at his book wrong and saw the windsheild or such, as those as stated are the same, but the difference in the rear window size is very obvious.
Old Jul 20, 2004 | 05:19 PM
74 F100 351m
So the windsheilds are the same?
Old Jul 20, 2004 | 06:23 PM
fellro86's Avatar
fellro86
yes, I have an extra form a 71 with intent to go in a 79. I researched it through a local glass shop and their order number is the same.
Old Jul 21, 2004 | 09:31 AM
74 F100 351m
Thanks for the info.
