Steering Wheel Correction
Old Mar 9, 2020 | 08:02 PM
TCNashville's Avatar
TCNashville
Long story short, my truck got rear ended a ways back and part of the fix the adjuster had them do a 4 wheel alignment. Ever since then the steering wheel is slightly cocked to the right. I thought for a long time I could live with it and I still can but if there's a relatively easy fix for this I'll do it. I believe the alignment is good as the truck tracks straight and true and no adverse tire wear. I've watched a couple of videos on how to do it and it seems I have to rotate that clamp by the tie rod end clockwise [down] to correct the issue. My question is do I have to have the front wheels off the ground and if I do this will another alignment be necessary? Thanks for any input.
Old Mar 9, 2020 | 08:08 PM
Section179's Avatar
Section179
Front wheels do not have to be off the ground, which is fantastic, because you’ll drive it 1,000 feet and want to tweak it another half turn.
Keep in mind when you turn the clamp you want to grab it in a way that promotes opening the clamp rather than closing. I use a pipe wrench with the wrench hooked just inside the opening of the clamp (not bridging it). Others may recommend a different tool, But I’ve been adjusting super duty steering wheel centers going back to ‘99s all laying in the dirt. Adjusting this will not change caster, camber, or toe in.... so no alignment needed.
Old Mar 9, 2020 | 08:45 PM
StonedGrey's Avatar
StonedGrey
Yep. ^^^
can be on the ground. No need to lift it off the ground.
Its simple once you figure it out.
Good Luck.
Old Mar 11, 2020 | 05:02 PM
TCNashville
Originally Posted by Section179
Front wheels do not have to be off the ground, which is fantastic, because you’ll drive it 1,000 feet and want to tweak it another half turn.Keep in mind when you turn the clamp you want to grab it in a way that promotes opening the clamp rather than closing.
Well I finally got to it. I watched another video and the guy turned his clamp 2 full turns so I'm thinking 1 full turn ought to do it. Wrong! It was more like 1/4 turn if that and that was the 3rd time I tried it. I PB blasted it yesterday and could almost turn it by hand after loosening the bolts today. You were right, 3rd time I think I nailed it.
Originally Posted by StonedGrey
Yep. ^^^
Good Luck.
It was simple and thank you both very much.
Old Mar 11, 2020 | 06:12 PM
ForCal's Avatar
ForCal
Mine came slightly to the right since new. What direction did you turn the collar?
Old Mar 11, 2020 | 08:33 PM
StonedGrey's Avatar
StonedGrey
Your welcome. Glad you got er straightened out. An off center steering wheel is annoying.
Old Mar 11, 2020 | 09:45 PM
TCNashville
I turned the collar down or clockwise for my steering wheel that was slanted to the right. Be wary, it shouldn't take much.
Old Mar 11, 2020 | 09:51 PM
ForCal's Avatar
ForCal
Thank you.
Old Mar 12, 2020 | 07:09 AM
abilliott's Avatar
abilliott
tagged, mines ever so slightly to the left so might be trying this out.
Armyrules2
Dec 11, 2017 09:51 PM
ep01
1983 - 2012 Ranger & B-Series
Sep 3, 2009 08:09 AM
fp_5
Sep 20, 2005 09:24 AM
seumas
Sep 25, 2004 08:38 PM
302FROGMAN
Jan 16, 2003 11:20 AM
