steering wheel alignment
Old Jan 14, 2003 | 08:25 AM
302FROGMAN's Avatar
302FROGMAN
How do you align the steering wheel so when its
straight your going straight
Old Jan 14, 2003 | 02:03 PM
John7894's Avatar
John7894
Have a front end alignment done on your truck.The guy will align the wheels with the steering wheel pointing straight.
John
Old Jan 14, 2003 | 03:52 PM
pbrstreetg's Avatar
pbrstreetg
Hi-
Or you can do it like this. Make sure your toe settings are equal, then let the truck drive itself straight. Yank off the steering wheel and put it back on where the truck wants to go straight forward by itself.
Old Jan 14, 2003 | 05:04 PM
Avanti's Avatar
Avanti
The alignment people screw one tie rod in and the other out the same amount of turns. Before doing this the toe in should be correct (same on the front & rear of the tires. I bought a toe in gauage from J C Witney years ago.Eastman also has it. So I have done the toe in correction & set the steering wheel on 74, 84, 89, 92, 93 Ford trucks and a bunch of antique vehicles.It is a good tool for just checking your toe in without having to pay an alignment shop.
Old Jan 14, 2003 | 09:11 PM
steve83's Avatar
steve83
Old Jan 14, 2003 | 09:25 PM
steve83's Avatar
steve83
pbrstreetg
No, the steering wheel & the whole column only fit together one way - it has to be done at the tie rod ends.
Old Jan 14, 2003 | 09:30 PM
pbrstreetg's Avatar
pbrstreetg
Please don't take this the wrong way, i'm not being a wiseass.
pbrstreetg
Not on my truck. The steering wheel has a good number of splines, when I take off the wheel i can put it back in alot of different clock positions. Sounds pretty gypsy, but I guess i'm cheap
Old Jan 14, 2003 | 09:35 PM
steve83's Avatar
steve83
The OE steering wheel has a flat inside, which matches a flat on the column shaft. There's a similar flat where the rag joint slips onto the steering box shaft, and another for the pitman arm on the sector shaft. If your OE steering wheel is damaged, OR if it was ever installed incorrectly, OR if you have an aftermarket wheel, you'd be able to turn it.
I was only referring to OE parts in good condition.
Old Jan 14, 2003 | 11:42 PM
Racerguy's Avatar
Racerguy
It depends on the year of the truck. Some have splines that you can move the wheel on, others have flats that the wheel only fits one way.
Old Jan 15, 2003 | 12:10 AM
bperkins's Avatar
bperkins
Joining in on this thread. I've got a **** poor suspension job that was done before I bought the truck. I'm by no means an expert, but it seems like it is screwed. I have a 93 F150 extended cab with 32.5's on it that rub on the front end even with a 3 inch lift. It has camber that only a baha bug could be jealous of. Would a allignment fix this, or would I have to buy a bunch of new stuff.
Thanks
Old Jan 15, 2003 | 01:11 AM
mrwizard's Avatar
mrwizard
bperkins,
It sounds like your lift kit wasn't installed properly. By your description, it sounds like whoever did the lift only put taller springs on the front, and didn't lower the middle of the axle to match the lift of the springs. Also, they may not have lowered the radius arm pivot locations.
My lift kit (done before I bought it) has new, extended radius arms that are a round tube design, and are actually curved in such a way that my tires don't come anywhere near them at full turn. Unfortunately, the dealership I bought the truck from sprayed undercoating on everything under there, so I can't see who's kit it is.
Old Jan 15, 2003 | 10:49 PM
bperkins's Avatar
bperkins
What type of shop would you take it to for inspection. I don't really have the time to learn how to do it right. Would you take it to an allignment shop? Would a 4X4 specialty shop have a better chance of fixing it? Thanks.
Old Jan 16, 2003 | 11:20 AM
mrwizard's Avatar
mrwizard
A specialty shop would probably be a better (but probably more expensive) choice. They would have more experience with 4X4 lifts and how they should be installed.
Dan Taylor
Dec 2, 2013 07:48 AM
'04 4.0 XLT
1983 - 2012 Ranger & B-Series
Jul 10, 2013 01:20 AM
cbzdel
Jun 20, 2012 10:24 PM
TNT
30
May 20, 2011 04:20 PM
PAUL_2
Jan 2, 2001 01:16 PM
