Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Warranty Plate Decode Request
Old Mar 9, 2020 | 11:05 AM
F830WI's Avatar
F830WI
Trailering
Can someone help me decode this warranty plate? It should be from a 1964 C1000. I am looking for details, especially which engine.
Thank You
Old Mar 9, 2020 | 02:55 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C00 = C1000 Tilt Cab.
R = 534 4V
U = Louisville KY Assembly Plant.
576570 = 1964.
153" Wheelbase.
J = Rangoon Red.
C000 = C1000 Tilt Cab, 32000 lbs. GVWR
A91B: A = Silver Gray Crush Vinyl & Gray Twill Stripe Woven Plastic // 91B = Custom Cab.
Q = Dana/Spicer model 6352 5 Speed Direct.
-H: - = Rear Axle was a Domestic Special Order // H = Rockwell/Timken model FG-903 15,000 lbs. Capacity Front Axle.
32,000 lbs. Gross Vehicle Weight Rating.
235 net HP @ 3,000 RPM
241051:
24 = Jacksonville FL Ford District Sales Office, where the dealer ordered the truck from.
1051 = Domestic Special Order number, truck ordered special by the original purchaser, not "bought off the lot."
Old Mar 9, 2020 | 03:24 PM
F830WI's Avatar
F830WI
Trailering
Thank you so much Bill!
Old Mar 11, 2020 | 11:09 AM
F830WI's Avatar
F830WI
Trailering
Hello Bill,
Would you be able to tell me the Motorcraft part numbers for the ignition coil and plug wires for this engine?
Thank You
Old Mar 11, 2020 | 04:30 PM
NumberDummy
Hello Bill,
Thank You
B6A-12029-B .. Ignition Coil (Motorcraft DG-5) / Obsolete
ALL 1956/73 FoMoCo vehicles except with transistor ignition // ALL 1974/75 FoMoCo vehicles without DuraSpark electronic ignition.
D6PZ-12259-R .. Spark Plug Wires (Motorcraft WR-3820-B) / Obsolete
1964/74 B/C/CT/F/L/LN/LNT/LT/LTS 500/900 with 330/361/391 FT engines & 1958/74 401/477/534 engines.
Old Mar 11, 2020 | 04:43 PM
F830WI's Avatar
F830WI
Trailering
Thank you sir. I am finding listings for the WR-3820-DR wires -- Would that be compatible?
Old Mar 11, 2020 | 04:54 PM
NumberDummy
Should be, the R refers to radio resistant.
Old Apr 8, 2020 | 11:33 AM
F830WI's Avatar
F830WI
Trailering
Hi Bill,
Looks like we need to do a timing chain on this truck as the chain jumped a notch. I am looking for part numbers for a timing chain, timing chain cover gasket, front crankshaft seal.
In an ideal world, it would be great to find the part numbers for the gears: crank and cam gear, and the crankshaft sleeve (if it had one).
If there are any cross compatibilities with this 534 and other Ford engines that might help also.
Any part number help you could give me would be appreciated.
Thank You
Old Apr 8, 2020 | 08:26 PM
NumberDummy
In an ideal world, it would be great to find the part numbers for the gears: crank and cam gear, and the crankshaft sleeve (if it had one). - None shown or listed.
1958/81 401/477/534
B8QH-6256-A .. Cam Gear - 110 tooth / Obsolete
CARPENTER NOS OBSOLETE PARTS in Concord NC has 2 = 800-476-9653.
B8QH-6306-A .. Crank Gear - 55 Left Hand Helical Teeth / Obsolete
3 on ebay, first two listings say Freightliner, 3rd listing is a genuine Ford part.
D3HZ-6020-A .. Timing Cover Gasket / Obsolete
GREEN SALES CO. in Cincinnati OH has 35 = 800-543-4959.
C4TZ-6700-A .. Timing Cover Seal (same as 1964/78 FT engines) / Obsolete
CARPENTER NOS OBSOLETE PARTS has 11.
GREEN SALES CO. has 166.
Old Apr 10, 2020 | 11:28 PM
Destroked 450's Avatar
Destroked 450
Hi Bill,
Thank You
534 doesn't have a timing chain, they are gear to gear.
Old Apr 11, 2020 | 12:59 AM
NumberDummy
You'll notice that I didn't list a chain in post #9...since there's no such thing.
Old Apr 22, 2020 | 02:55 PM
F830WI's Avatar
F830WI
Trailering
Thanks for all the help here Bill--again. Bob at Carpenter is not working during the COVID crisis but they promise me that as soon as he comes back to work in 3-4 weeks, he will call me about the Cam gear. I did get the crank gear on eBay and the gaskets from Green Sales. They were awesome. Thanks again!
Old Jul 7, 2020 | 12:43 AM
F830WI's Avatar
F830WI
Trailering
Hi Bill,
I need help with a few more parts please:
Can you direct me to what I should search for to find a replacement stock carb for this truck? When I search for carbs for the 534 I get different year ranges and I want to find the correct one for 1964.
Also can you provide me the part number of the ignition switch and ignition switch lock cylinder?
Thank You!
Old Jul 8, 2020 | 01:32 AM
third66go's Avatar
third66go
Your carb should be a C3TE-9510-D. It is set up for a mechanical governor - later versions used an electrical type which was a different P/N.
It can be rebuilt; you can use a current production kit (Holley 37-485, $45) for a Holley 4150, and reuse all the hard parts that made it unique for the 534 engine. If someone has one on the shelf ready to go, beware if it has been sitting for years and the soft parts are no longer safe and reliable. You could replace it with a new Holley O-1850S, but it would not be calibrated and jetted specifically for a 534, and you would lose the governor function. The Holley factory store currently has some factory refurbished ones for $200. One secret to keeping the 534 working hard and lasting for the full 100,000 mile warranty was that the Ford/Holley engineers made sure it never ran lean under load, so the carbs were tuned to burn fuel by the barrel when working hard. At one time there were different calibrations depending on whether the truck had oil bath or dry paper air filters, so I'm guessing they really did spend a lot of time to get it right...
I would guess that '61-'66 F-series ignition switches/cylinders/locks are the same on the C-series.
We haven't heard from Bill/ND in a while, I hope he will chime in soon!
Cheers
Old Jul 8, 2020 | 09:47 AM
F830WI's Avatar
F830WI
Trailering
Thanks! Does it have to be exactly the C3TE-9510-E of would C3TE-9510-X (where final letter suffix is different also work?) if not, what are the years they used the C3TE-9510-E to see about cross reference finding one?
