Missing hose or plug - Code 0174
Old Mar 7, 2020 | 08:15 AM
2002 e450 V10's Avatar
2002 e450 V10
Good morning,
2002 E450 V10 on a 31' Winnebago motorhome. 96,000 miles. Maintenance has always been done and until yesterday it has always run perfect.
Hoping someone can help me out with this. I've searched everything I thought might apply but am coming up empty. Yesterday my motorhome threw a 0174 code. I removed the doghouse to have a look around. Other than the mouse nest on top of the engine, seemed to look okay with one exception. This port that looks like a hose should be on it. I don't see any hose in there flopping around or anything else that would indication where the other side of this might attach. When I put my finger over the port, it smooths out the idle very nicely. There is a significant vacuum pull on it.
Should this be capped / plugged? Did my resident mouse make a meal of the cap and it fell off?
Any suggestions and advice? Thank you in advance.
Old Mar 8, 2020 | 05:43 AM
JWA's Avatar
JWA
Find the PCV valve and see if the hose from it to the base of the throttle body is intact---if not that might be your missing hose.
Not sure if a mouse would/could eat that hose so completely its missing altogether as your images show. To my eye it looks as though something hasn't been connected to the stub in a long time.
Good luck with this!
Old Mar 8, 2020 | 09:57 AM
2002 e450 V10
Thanks. I plugged it and we're running smooth again. Service light hasn't come back on so fingers are crossed that the issue is resolved.
DSMCasey
1997 - 2003 F150
Oct 5, 2016 08:24 PM
PMDRACER
Jul 16, 2013 05:39 AM
ls1z28
Escape & Escape Hybrid
Dec 6, 2011 06:35 PM
rcn
Jul 27, 2009 06:26 PM
easpilman
Jul 3, 2003 12:08 PM
