7.3 IDI running issues
Old Mar 6, 2020 | 09:18 PM
Markcoultes's Avatar
Markcoultes
Recently did head gaskets in this rig. Has a real low idle. Smells like it is over fueling. Has this loud thumping/sucking noise through the air intake. Any ideas? Let me know if the video doesn’t post. Thanks.
Old Mar 6, 2020 | 10:12 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
did you remove the IP assembly while doing this job... IF so you probably didn't get the gears lined up right. Just my first Guess
Old Mar 6, 2020 | 10:26 PM
DarkOverCast's Avatar
DarkOverCast
This, you may also have some failing lifters
The fact you mention overfueling makes me think the exhaust would be blowing smoke of some kinda colour
Old Mar 6, 2020 | 11:54 PM
Markcoultes
I unbolted it and lifted it high enough to clean the rtv off it. I’m fairly certain I put it back the way it was. But would that explain all the symptoms I have?
Old Mar 6, 2020 | 11:55 PM
Markcoultes
Has quite a bit of light colored smoke. Smells of fuel pretty bad.
Old Mar 7, 2020 | 07:50 AM
Forddiesel17's Avatar
Forddiesel17
You need to take the round cover off of the front of the timing housing. Turn the engine over until you see the timing marks on the gears. Make sure they are lined up. If you lifted the housing there is a very good chance that the timing is off. That is were I would start.
Old Mar 7, 2020 | 08:18 AM
RaymondIV's Avatar
RaymondIV
If you remove the pump from the gear and cover so you can remove it, it will be out of time for sure. Plus you can't just look down and "see" the timing mark on the cam gear.And if you're referring to the IP to gear bolt access cover, no way you can see marks there either.
[QUOTE] Has this loud thumping/sucking noise through the air intake.[/QUOTE]
Mark, that's normal on any diesel because there's no throttle plates to isolate intake and combustion noise like a gas engine.
Vinford
Nov 2, 2015 04:42 PM
pentastarjim
Feb 13, 2010 06:31 PM
