headlight conversion bronc graveyard
Old Mar 7, 2020 | 06:04 AM
i-w's Avatar
i-w
when I used that harness, I had to remove the crud surface
rust and some paint to get a better ground.
my harness has both high and low on when high beams are
on. I got sealed Sylvania bulbs. the harness was a good
difference compared to original harness.
no issues.
Old Mar 7, 2020 | 08:08 AM
72rtchallenger's Avatar
72rtchallenger
Originally Posted by 1TonBasecamp
The high-beam indicator lamp is powered by the right headlamp circuit. As another test, try disconnecting only one or the other headlight.
So disconnect the driver's side lamp and turn on the high-beams. Then re-connect it and do the same test with the passenger side. See if it makes any difference either way.
Paul
I do plan on trying this and few things, thanks
Might as well check battery voltage while you're at all this testing. Off and running both. Should be approx. 12 to 13 volts, depending on how long before that the engine had been running. If it's been sitting awhile since last charged, 12.3 to 12.6 volts. When running you should see 14.5v approx. even with all the accessories running amuck.
Not sure that the relay harness enhances safety, per sé. But it makes sure that the lights are getting full system voltage rather than a somewhat lesser value.
If the rest of your wiring is in great shape, your lights should still work fine without them.
I installed relays in both my Bronco and F350 probably 30 years ago now. Neither had anything like what you're experiencing.
Paul
I may run them without new harness if I cant figure this out, I may make my own harness with relays , and I need to check new harness better an connections and battery is new but do need to go thru all connections an grounds at battery
Originally Posted by John89
It couldn't hurt (kow) to clean and smear some di-electric grease on the dimmer switch connections.
I use di-electric grease on all connections , its good stuff
no issues.
Yeah mine is fresh paint but have cleaned the grounds for harness an use star washers , but do plan on removing it to inspect , as it sounds like a ground issue to me as well
whiteisright
Oct 25, 2011 11:26 PM
BIGskinny
20
Jun 5, 2011 01:57 PM
lon371
1997 - 2003 F150
Jan 30, 2005 11:21 AM
Dj300ford
Aerostar
Dec 13, 2003 02:17 AM
