headliner .pdf
Old Mar 6, 2020 | 11:33 AM
mulegal's Avatar
mulegal
headliner .pdf
Hi all, I remember someone here had a pdf file that can help plot a new headliner on new material. 1965 F100 custom cab. If anyone can share this I sure would appreciate it.
Old Mar 6, 2020 | 12:05 PM
TA455HO's Avatar
TA455HO
Lead Gopher
https://www.ford-trucks.com/forums/1...l#post16595577
Should be links to dropbox where you can grab them still. Duplicated here, too.
https://www.dropbox.com/s/64hnfocyei...0Dome.pdf?dl=0
https://www.dropbox.com/s/fhcc098wqe...ner_1.pdf?dl=0
Old Mar 6, 2020 | 01:01 PM
mulegal's Avatar
mulegal
Thanks much Chad. Appreciate this.
Old Mar 6, 2020 | 07:49 PM
Rollbar's Avatar
Rollbar
Originally Posted by TA455HO
Thanks, I guess the '65 F250 Custom Cab and the others are the same size?
Saved the PDF.
Old Mar 6, 2020 | 08:24 PM
F100 '64's Avatar
F100 '64
Thanks guys I downloaded them again. I tried once before to get these printed out without success. Any tips I can give my guy on printing these?
Thanks, Pat
Old Mar 7, 2020 | 04:52 AM
Iowaf100's Avatar
Iowaf100
Trailering
I don't need this yet, but I am going to. Thank you.
Old Mar 7, 2020 | 10:12 AM
TA455HO's Avatar
TA455HO
Lead Gopher
Thanks, Pat
Read this post. It requires a plotter of at least 36" in size. It is drawn to scale so if you print it without adjusting the scaling that's how it was designed.
https://www.ford-trucks.com/forums/1...l#post11250917
Old Mar 7, 2020 | 08:18 PM
F100 '64's Avatar
F100 '64
Thanks for the link, I copied the info and will try again. If he can't get it to print I probably will try going to a Kinko's and see if they can do it. ~Pat
Old Mar 10, 2020 | 02:18 PM
mulegal's Avatar
mulegal
Progress being made....got the 2 .pdf files printed at local copy center for under $10. Good!
picked up a .090 X 4' x8' sheet of plastic sheathing. There were 3 thicknesses...one was very heavy and un bendable, one was flimsy not even support it's own weight. I got mid range. Parkland waterproof panel. once home I noticed label said not for use in trailers and rv's. Said to install it at normal temp of location? it is a sheet of thick plastic with a stucco appearance molded into it.. Now not sure...was $40 and I can return if not right.
So what is RTF that was recommended? Fiberglass of some sort?
Old Mar 11, 2020 | 08:31 PM
2dwoods's Avatar
2dwoods
I bought a perforated one from carpenters
Old Mar 11, 2020 | 09:30 PM
F100 '64's Avatar
F100 '64
Thanks again TA455 for the link to the other post. I got it printed out today by my guy at work. ~Pat
Bonnie Fletcher
Aug 13, 2019 06:50 PM
BullDog58
WTB - Parts & other
Mar 22, 2017 02:09 PM
Gcwstang
Vehicles for Sale
Jan 5, 2016 12:08 PM
ford66
Sep 26, 2009 06:54 AM
