I think I sorted paper size by viewing the files and noting there are some dimensions listed on each file and then custom selecting a paper size several inches larger than the biggest dimension, my plotter uses 36" wide rolled paper so I set that as the width and for the top panel I think I selected something like a 74" length, then selected "none" under the page scaling option and printed, I was able to check the final print using the dimensions noted against the actual print to verify its the correct size. I had a miscue the first time I tried to print because I didn't select a large enough paper size (there are build in margins) so go bigger than you think and you should be fine.
Any chance you (or anyone) have this headliner .pdf file? I didn't have any lucl downloading form the link - had an error message saying the download limit was exceeded. Thanks!
Looking for anyone that still has the headliner pdf? If anyone has it and can email that would be great thanks. I don't have enough post for pm yet. Johaness_00@yahoo.com
I just sent you copies of the PDF's. They can be printed on any 36" Plotter.
JP1222, I am glad to send you the pattern but you should note, it is for a 1965-1966 F series. I believe there are some differences between the 1962, and those. Send me your email address, and I will send you the pattern. If you manage to make a pattern that works for 1961-1964, then you may want to let others know what you did.
If you click on a username like Broomfieldbum it will pull down a menu that gives various options, one of which is "Send a private message to Broomfieldbum". Here's a screen shot of what it looks like.
