T4 turbo setup
Old Mar 4, 2020 | 04:00 PM
Steelheader87's Avatar
Steelheader87
T4 turbo setup
I am interested if anyone has worked with a reputable mechanic in Oregon or anyone in Oregon (near Salem) who would want a side job to install a T4 and all the fixings?
Old Mar 4, 2020 | 10:05 PM
kbeefy's Avatar
kbeefy
2 of the bigger T4 7.3 guys are over there in the valley. Have you talked to them?
Irate Diesel and Obsesion (I think)
Old Mar 5, 2020 | 03:17 PM
Steelheader87
Thanks for the input, what is everyone's opinion on the Obsession kit?
Old Mar 5, 2020 | 03:45 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
If I were choosing between those two I would go with Obsession in a heartbeat...
@Markus Luukko installed one of these kits not too long ago.
https://www.ford-trucks.com/forums/1...el-t4-kit.html
Old Mar 5, 2020 | 04:52 PM
Steelheader87
Can you explain why you would recommend the Obsession kit over the Irate kit?
Old Mar 5, 2020 | 05:10 PM
Sous's Avatar
Sous
FTE Emeritus
The main reason is because of the way the oil return line is designed. Other than that it is a toss up between the two and personal preference.
I have been told by at least two people I trust that the Irate kit is good, but the oil return line is a major pain in the ***.
Old Mar 5, 2020 | 05:56 PM
Steelheader87
So the installation is difficult, but overall performance is ok?
Old Mar 5, 2020 | 06:17 PM
Sous's Avatar
Sous
FTE Emeritus
The performance of the various kits is going to be nearly identical as it is just plumbing, a plate, nuts and bolts. Take a look at the Irate kit oil return line and how it goes into a freeze plug in the valley.
I don't know about you, but I was not interested in putting another hole into the valley of my engine. The two people I trust that have installed the kit say it was good, but getting the oil return line right was a pain in the ***.
The Obsession kit, just like the CSD kit use the factory oil supply and return ports. That may not be important to everyone, but it was for me.
Again, performance is gained (or lost) in the turbo, not the pipes and clamps that are attached to it.
Old Mar 5, 2020 | 06:39 PM
Steelheader87
Sous, thanks for your replies, what do you think is a reasonable cost to have someone install a kit?
Old Mar 5, 2020 | 07:41 PM
Sous's Avatar
Sous
FTE Emeritus
Well, I can not give you an estimate because I honestly don't know. If I were in your position I would see if Obsession has a shop or two they can recommend. Maybe get in touch with Clay at Riffraff and see if he recommends anyone.
Maybe go to the FTE chapter sub-forum and ask for a trusted shop.
Quality of work is more important than price in my opinion.
Old Mar 6, 2020 | 06:08 AM
SkySkiJason's Avatar
SkySkiJason
I installed my Irate kit and S366sxe back in 2009?
The freeze plug is no big deal, but fitment of the return oil hard line is a pita. I will likely have a hose made for this if I have mine out for some reason.
Old Mar 7, 2020 | 03:55 PM
Steelheader87
Thank you for your reply Jason. Irate is 20 minutes away from me and one of their employees can install it for me. I think I am going to go that route.
Old Mar 7, 2020 | 04:35 PM
Sous's Avatar
Sous
FTE Emeritus
You will be pleased with the kit and definitely have to give us updates when you stop smiling and laughing at how well the engine runs.
Miller
Dec 30, 2006 07:19 AM
jadel
Mar 23, 2005 06:02 PM
tristankc
Feb 20, 2004 10:28 AM
