Question on these front end brackets
Mar 4, 2020 | 08:20 AM
Trailering
Mar 4, 2020 | 08:28 AM
It's your truck. Grab a torch and take them off if you want.
Mar 4, 2020 | 08:31 AM
Quote:
Originally Posted by
rjr6/150
I believe those are the backing brackets for the air dam...🤔
Mar 4, 2020 | 08:42 AM
Those are the “Prius catchers”. They un bolt from th frame from 4 bolts each iirc.
Mar 4, 2020 | 08:48 AM
I believe they are there to keep the truck from going over another vehicle in an accident. Your new front receiver hitch will do the same job if you even care about such a function.
Mar 4, 2020 | 08:55 AM
Yup, i took mine off when I did the 2wd valence. 4 bolts and it comes off.
Mar 4, 2020 | 09:04 AM
I installed a front receiver with out having to cut anything except for the square hole in the air dam.
which receiver are you installing?
Mar 4, 2020 | 09:11 AM
Texas78028
"Prius Catchers" are bolted on, but I'm all for the torch method.
Mar 4, 2020 | 09:12 AM
Mine were removed when the snowplow frame was installed.
Mar 4, 2020 | 11:41 AM
Trailering
Thanks everyone. Receiver installed
Auger Hekla
Aug 20, 2017 09:11 PM
Popeyedc65
Apr 27, 2017 08:46 PM
BaggedMerc
27
Mar 6, 2016 09:00 PM
My1964ford
Oct 25, 2014 11:33 AM
strokin'_tatsch
66
Feb 14, 2010 05:56 PM
