02 Expl abs issue
Old Mar 4, 2020 | 05:57 AM
Dave Kalena's Avatar
Dave Kalena
02 Expl abs issue
HI all, Have a issue with my 2002 explorer. Just redone all wheel bearings, brakes, and the 1155 code keeps popping up, Now the left frt wheel bearing is new [ Timken, USA made with a brand new abs sensor, So why does the code keep popping up?? Reset/ Cleared 2/3 times, and its back. Any Ideas??
Old Mar 4, 2020 | 03:30 PM
shorod's Avatar
shorod
There's more to the LF wheel speed sensor circuit than just the sensor. I assume you're referring to a C1155 diagnostic code. The issue could also be with the wiring between the sensor and the ABS computer. It's also possible (albeit unlikely) that the new sensor is bad. You'll want to carefully inspect the wiring from the sensor to the ABS module. Does your scan tool allow you to monitor the ABS system datastream? If so, is that sensor reporting a reasonable speed compared with the other wheel speed sensors?
-Rod
Old Mar 4, 2020 | 06:05 PM
Dave Kalena
First off Thankyou for responding, No my scan tool is not that advanced. I'll take a closer look at the wiring. Thanks again for the response.
Dave
Brenda Lamka
28
Apr 6, 2014 10:39 PM
kjester
15
Mar 17, 2011 02:31 PM
Drizzt
2004 - 2008 F150
Feb 18, 2009 09:44 PM
dennyo
Feb 11, 2009 09:49 AM
maa139
Nov 7, 2004 03:54 PM
