electrical problems
Old Oct 14, 2003 | 04:15 PM
74knight's Avatar
74knight
electrical problems
i have a 74 f100 with 351c and wooden bed. when switch is on rear light stay on,also rightside turn signals doesnt work.light comes on dash but doesnt blink,hazard works fine,when lights are on alt. light stays lit. help!!!
Old Oct 14, 2003 | 04:24 PM
stepman's Avatar
stepman
When your 4-ways rae on do all of the external lights flash? Sounds like you have a bulb out or maybe a flasher.
When what switch is on what light stays lit?
Need to check your charging sytem for the alt light. Does it go off if the idle is raised?
Old Oct 14, 2003 | 05:27 PM
74knight's Avatar
74knight
when headlights switch is on alt. light stays on,when headlight switch is off alt. light goes off.when hazards are on the lights work properly.
Old Oct 14, 2003 | 06:13 PM
TheWiz427's Avatar
TheWiz427
Since you have a wood bed it might be a ground problem with the tailights. As for the alternator it sounds like it might be weak i would have it checked.
SuperDuty93
Dec 1, 2012 03:32 PM
joshcwa
Sep 2, 2012 02:59 AM
Nathan Plemons
22
Jun 29, 2009 09:39 PM
fishel74
Mar 14, 2008 03:32 PM
Hbeckett
Electrical Systems/Wiring
Aug 8, 2004 10:55 PM
