Brake lights dont work...?
Old Dec 1, 2012 | 11:21 AM
SuperDuty93's Avatar
SuperDuty93
Ok all of a sudden my brake lights dont work. They blink left and right but the flashers dont work, they light up with the running lights but they dont get brighter when braking. What could this be? Sounds like a short to me....
Blinkers and running lights (1 filament works while headlights etc are on)
Flashers and braking doesnt work...
This is on my 74 btw
Old Dec 1, 2012 | 11:39 AM
V10man's Avatar
V10man
I'm kinda confused. Blinkers, flashers and brakes are all the same in the rear.
Old Dec 1, 2012 | 12:25 PM
fmc400's Avatar
fmc400
MSEE
Right, but the circuits feeding this common filament are different. One can fail while the others remain in operation.
The brake lights and emergency flashers share the same fuse. Since these are the only things not working, check for power on BOTH sides of the fuse with a test light. Both sides should be hot at all times; I suspect you will only find one of them is hot. If that's the case, and there's no obvious signs of damaged wiring, replace the fuse. If it blows again, then we'll troubleshoot further. Fuses do get old and blow on their own.
Old Dec 1, 2012 | 03:10 PM
SuperDuty93
Ok leme check the fuses again. None looked broken or burnt out. Ill go find my tester. Which fuse is it on there btw?
Old Dec 1, 2012 | 03:32 PM
SuperDuty93
FIXED IT! Bad fuse. wasnt broken but it looks like it fried in the metal casing part so it looks 100% fine from the clear part. Weird. But hey thanks guys
Mick.longacre
18
Sep 23, 2016 05:32 PM
xmontex4
Oct 6, 2014 08:12 AM
mgc_ocp
Large Truck
May 10, 2011 09:06 AM
mikechamp05
Feb 18, 2011 07:59 PM
vqarabs
Electrical Systems/Wiring
Feb 3, 2001 04:00 AM
