Alternator P0620 code
Store replaced alt under warranty.
Now ALT DOES NOT CHARGE.
Had it in and out repeatedly, chk'd fuse & mega fuses at power block, connector does not appear damaged. Have 12 v on red wire @ alt.
Took alt to store, tested good. Took car to local shop, they think it is the alt.
Any ideas?
2010 3.0 V6
__________________________________________________ __________________________________________________ _______________________
Store waranteed alt again, no change
Cables are good, terms clean & tight.
Code P0620, Generator Control Circuit.
PIDs Gen Command Line Fault
Generator Fault Status Yes
Gen Monitor Line Status Fault High
I get battery voltage when engine is running. Batt Light comes on.
If I rev it up to about 3k it will start charging at 13.8v which apparently is a failsafe mode. It always ran at 14.5 to 14.7 before.
Have 12v @ stud to battery.
I cannot reach to probe 3 wire connector when connected to alt.
Disconnected I read
KOEO KOER
red/brn 12v 12v
grn/or .06v 1.9v
Purp 12v 12v
Took it to an auto electric place purported to be the best in the area by someone I respect. The owner told me they do not believe the alternator is a quality part (from a national chain).
He said "Yes we are here to make money, but not by ripping anyone off" "save yourself my markup and labor charges" "The first thing I will do is replace the alt so go get one from NAPA and replace it".
Unfortunately that did not fix it. I am getting concerned that this may be a PCM issue.
Any thoughts?
