Sponsored by: Real Truck
battery draw
Old Mar 2, 2020 | 05:17 PM
rhanft1965's Avatar
rhanft1965
battery draw
Still trying to diagnose my electrical glitch with one new question what should the current draw be off of the battery with everything off? Hood is open only enough to read the ammeter no under hood light on. Thanks 1999 F250 SD V10 92K Miles
Old Mar 2, 2020 | 06:43 PM
projectSHO89's Avatar
projectSHO89
After 35-40 minutes from touching ANYTHING, current draw should not exceed 50 mA.
If you do not wait the required timeout interval, you'll end up wasting time and money.
Old Mar 4, 2020 | 06:14 PM
rhanft1965's Avatar
rhanft1965
battery draw
Thanks for the reply performed the current draw test and after an hour it dropped to 7.5 mA. Doesn't seem too bad but when I turn the key on the battery indicator blinks secondly at idle the dash lights/indicators/dome light flicker. Brand new Interstate battery (old on was 6 years old) rebuilt alternator (old one was surging while charging). Checked all grounds except ones behind kick panels. Appreciate any info.
Thanks
Rob H1965
Old Mar 4, 2020 | 09:14 PM
projectSHO89
That's an indicator that the alternator output is not correct.
Old Mar 5, 2020 | 08:20 AM
99f350sd's Avatar
99f350sd
My 99 takes a minute or 2 to read 40 ma..depends on options your truck has.
Sounds to me like you either have a bad alt or connections at the starter solenoid are bad...Check all big wires and rip the alt out and have it checked.
Old Mar 5, 2020 | 09:08 AM
redford's Avatar
redford
FTE Leadership Emeritus
What is your charging voltage? If it is under 14v your rebuilt alternator isn't working.
Old Mar 5, 2020 | 05:45 PM
rhanft1965's Avatar
rhanft1965
battery draw
Thanks all for your input,
The charging voltage with the rebuilt alternator fully loaded hangs around 15 volts, I did notice that the am radio without being on a station does wine louder when revved.. I am going to check the solenoid connections tomorrow.
Thanks
Rob H 1965
armyaviation
13
Oct 5, 2012 09:45 PM
Ford79
Feb 1, 2010 11:12 AM
preppypyro
19
Nov 23, 2008 07:56 PM
gdc25
Escape & Escape Hybrid
Oct 19, 2004 08:59 AM
