Brake controll module fault
Old Mar 1, 2020 | 08:57 AM
carlsson's Avatar
carlsson
I just bought a 2012 f250 that has a message in dash that there is a trailer brake module fault. I took it to my local hitch house that said it was the 7 pin plug but after I replaced that the fault message ius still there. Is it almost always that the module itself has to be replaced with this fault message? They tested the brake controll feature and said it worked.
Old Apr 10, 2020 | 11:59 AM
AR2008F250's Avatar
AR2008F250
I just replaced a Tekonsha aftermarket controller with the OEM in-dash controller with the Upfitter switch panel; I expected, and got,he same message. My model is an XL and did not come from the factory with the TBC and the master cylinder does not have the second, required brake pressure transducer. Once I get the master cylinder installed with the transducer (SU8540 on amazon.com), I expect the message will no longer appear.
Old Apr 10, 2020 | 04:06 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
yes, It will...until you get the computer reflashed to show the new master cylinder.
Old Apr 10, 2020 | 04:39 PM
AR2008F250's Avatar
AR2008F250
Have FORSCAN and enabled controller. Any other modules to enable? Thanks
Old Apr 11, 2020 | 08:09 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
That I am not sure of....maybe the controller itself?
BillTSD
Oct 31, 2020 10:59 PM
Shawn Donnelly
Apr 23, 2017 08:50 AM
missionarymike
Mar 22, 2014 08:16 PM
fairhaven
Oct 6, 2012 05:34 PM
twinpine
All Things Towing
Aug 1, 2010 09:17 PM
