AEB - Automatic Emergency Braking
Old Feb 29, 2020 | 05:19 AM
North Farms's Avatar
North Farms
I’m considering a 2020 F250 Lariat, but the AEB is a non-starter for ranch work. Several dealers have told me AEB can only be turned off via dash menu, and must be done each time the truck is started. I have to call BS on this, but the message from dealers has been consistent. Is it possible to permanently disable AEB?
Old Feb 29, 2020 | 07:48 AM
Joe T's Avatar
Joe T
You could probably just block the radar by changing the bumper to one that doesnt have a provision for it. Would warn you on start up.
Not permanent as you can swap bumpers when you sell it.
Old Feb 29, 2020 | 08:42 AM
NStorm's Avatar
NStorm
You can disable adaptive cruise in the setting menu and just run normal cruise, I believe this disables the emergency braking.
Old Feb 29, 2020 | 09:09 AM
Joe T's Avatar
Joe T
I think you can also pop the radar cover off and put something inside the cover that would block the signal.
Old Feb 29, 2020 | 09:39 AM
ford390gashog's Avatar
ford390gashog
Not sure why AEB is an issue for you? The AEB is not very sensitive in my opinion. I cruise in and out of road closures and through sand barrels daily and The AEB has only once in the short time I have had this truck gone off and that was when I was over 20mph and passed very close to the back of a flat deck trailer. Maybe take one for a drive, I know the wife's 2020 explorer is overly sensitive and beeps all the time and it is irritating.
Old Feb 29, 2020 | 12:05 PM
Section179's Avatar
Section179
Unless it changed significantly from 2019 you can herd cattle or push open a swing gate just fine. As others have said you can soft or hard disable it. Some metallic duct tape on the radar box is a dead simple hard override
Old Feb 29, 2020 | 01:08 PM
North Farms
Bumping gates and pushing through a herd is exactly my concern; as well as a few switchbacks that are near impossible with a full size truck- I’m imagining the AEB stopping me just as I need momentum to climb a hill.
Thanks for the ideas, I will demo a truck and try a few of these suggestions before ordering.
What are the plow guys doing with front sensors/aeb/adapt cruise? Are the days of hanging bikes or spare tire off the front of a truck or rv gone? This is what happens when you keep a truck for 200k miles, too much new technology to wrap your head around.
Old Feb 29, 2020 | 01:41 PM
tickpop's Avatar
tickpop
4wd Low
It doesn't on the 2017 SD. Ive had my adaptive cruise disabled since day 1 and the AEB is still engaged.
Old Feb 29, 2020 | 02:56 PM
1olddogtwo's Avatar
1olddogtwo
Get a warning that it's blocked, clear the screen and plow away.
Could be wrong, not familiar with the 2020 model. Thought it was only active about 20mph.
Not familiar cows, how fast can you hit them?
Old Feb 29, 2020 | 02:59 PM
1olddogtwo's Avatar
1olddogtwo
I was doing a job in Hattiesburg, just about every in the morning 3 months), I went under a certain overpass, I would almost get the beep/red alert but never automatic brake, 2017 at the time.
Old Feb 29, 2020 | 03:56 PM
Brian Exline's Avatar
Brian Exline
Bumping gates and pushing through a herd is exactly my concern; as well as a few switchbacks that are near impossible with a full size truck- I’m imagining the AEB stopping me just as I need momentum to climb a hill..
That's not how it works. It's quite passive imo. I've occasionally gotten a warning when a car in front of me is turning and the truck thinks I should have slowed down more but have never had the braking system activate. Crawling around on switchbacks or opening gates is so slow, it will never activate. It's good to research and ask questions but I don't think this one should stop you from making a purchase.
Old Feb 29, 2020 | 08:27 PM
scottz99's Avatar
scottz99
Veteran: Navy
AEB must be an additional option. I have "pre-collision assist" but that is not the same; it charges the brake system but does not automatically apply brakes.
Old Mar 1, 2020 | 04:19 PM
mhoefer's Avatar
mhoefer
AEB only acts IF you hit the brake pedal. It gives you a warning in the heads up display, but it doesn’t actually do anything unless you touch the brake pedal, and you have to be going faster than 20 mph, and you have to be closing on an object significant enuogh to be warning you of imminent collision. It will not be triggered under these circumstances your worried about in my opinion. Easy enuogh to disable anything in the menu or use Forscan, or have the dealer in IDS.
Old Mar 1, 2020 | 04:43 PM
scottz99's Avatar
scottz99
Veteran: Navy
Hmmm, that is what my manual calls "Pre-Collision Assist". And it works at speeds above 5mph. I'm still not clear what AEB is.
File Type: pdf
Old Mar 1, 2020 | 05:28 PM
Hawk328's Avatar
Hawk328
This Ford video, while not specific to the Super Duty, indicates otherwise. It states that what you're referring to is the second condition(collision warning being the first) it enters, but that a third condition WILL apply the brakes without driver input. It can also be disabled under the settings menu...but will default back to Enabled each time you start the vehicle. I'm sure it can be set to default to off with Forscan...but I bet a dealer won't do it for fear of liability.
