Fusible link for glow plug controller
Old Feb 26, 2020 | 09:40 PM
kman4443's Avatar
kman4443
Good evening fellow IDIers
Does anyone out there know where I can purchase the proper fusible link for my glow plug controller battery to controller wires?m (My truck is a 1988 F250 7.3 IDI) I checked the constant power wires to my glow plug controller from the battery and got 0 volts. I'm pretty certain the fusible link blew when the last controller went bad and I just replaced it.
Old Feb 26, 2020 | 11:03 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
you can buy Fuse link wire from most all local Automotive parts stores... if you can be more specific to which wire failed I could lead you to a proper replacement IE an in line fuse maybe could also replace the fuse link.
Old Feb 27, 2020 | 05:35 AM
kman4443's Avatar
kman4443
I believe its the two thick yellow wires in the harness that come from the battery to the controller. They are supposed to provide constant voltage to the controller. I measured them using a multimeter and got 0 volts. I need to dig a little further, but my bet is the fusible link in it burned up and that would be the weakest link.
Old Feb 27, 2020 | 06:46 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
Sounds like you on the right track... I've seen em replaced with inline Fuses and even inline Circuit Breakers too...I've also seen em wired back in with no protection at all <<== I don't advise that route.
Old Feb 27, 2020 | 07:53 PM
kman4443's Avatar
kman4443
Yes, I don't know why anyone would straight wire it without the fuse or fusible link. I guess they like their truck "Extra Crispy". LOL
bluef10069
Jan 3, 2017 04:24 AM
Ricky Kuczmarski
May 2, 2016 08:15 PM
CGMKCM
Dec 11, 2014 08:10 PM
tjc transport
Jan 13, 2014 09:54 AM
jqp00002
16
Jul 25, 2005 12:15 AM
