highboy diesel
Old Feb 25, 2020 | 01:11 PM
Awbucco9's Avatar
Awbucco9
highboy diesel
still working on swapping out my 400 for a 4bt cummins, running into some problems and looking for some advice, the truck has power brakes so im not sure what to do to make it functional with the new engine, also im not sure what to do with the power steering. If anyone has any advice or general experience with swap like this please message me, all info will be greatly appreciated.
Old Feb 25, 2020 | 06:51 PM
Lrrr-RulerOfOmicronP's Avatar
Does the 4bt not have a hydraulic pump on it? You will need to replace your vacuum power booster with a hydroboost set up. If you search the forum there will be many examples. Probably a lot of Cummins swap examples as well.
Old Feb 25, 2020 | 07:02 PM
hail destroyer's Avatar
hail destroyer
Stroke the 400 out to 434 ci, add some good heads and put it back where it belongs. Brakes and power steering brackets should line right up for you then.
Bonus? 50 more years of reliable operation while embarrassing the "gotta have a diesel/coyote/LS" swap folks with 50 year old technology.
Old Feb 25, 2020 | 07:10 PM
Pull it with a horse and avoid all that stupid technology!
Old Feb 25, 2020 | 07:54 PM
i61164's Avatar
i61164
Will that achieve 25 mpg?
Old Feb 29, 2020 | 11:37 PM
Nash1974's Avatar
Nash1974
Keep looking around through build threads you'll find several options. You could add a vac pump or convert to hydroboost. If you can't seem to find what suites you I want to say oilburners and pirate 4x4 have engine swap forums as well. A little reading can save a lot of headache
Old Feb 29, 2020 | 11:40 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
One of the best diesel conversion threads out there. https://www.ford-trucks.com/forums/1...rns+oil+burner
And a bunch more. https://www.ford-trucks.com/forums/s...rchid=29636679
Old Feb 29, 2020 | 11:54 PM
ford390gashog's Avatar
ford390gashog
You will need the Dodge power steering and vacuum pump to make this swap work. I take it this was an industrial 4BT? What's currently installed in the power steering gear drive or is it just covered with a blank?
Old Mar 1, 2020 | 03:13 AM
Tim Young's Avatar
Tim Young
Active Streak: 30 Days
Subscribing
Orr353
6.7L Power Stroke Diesel
May 7, 2010 06:08 PM
Diesel Fiend
Jun 4, 2008 09:04 AM
axkiker
General Diesel Discussion
17
Sep 6, 2007 12:07 PM
LaredoF350
Jan 19, 2007 11:32 PM
