Metallic Tapping when Accelerating
Oil pressure ~50
Temp ~ 185
Idles ~950-1100 (My truck doesn't really like idling lower)
Oil changed less than 100 miles ago
2 videos posted below:
Thanks guys!
The only thing I did change, a day ago, is I lowered the truck a bit, so I put shorter coils in the front and moved the springs up using the DJM kit. I bought 6 degree shims but didn't put them in yet. I thought I might have drive shaft issues but it seemed fine (I only drove it a few miles), but once again this can't be the problem because I'm having this issue when my truck isn't moving.
I have low oil, it was barely touching the dip stick, I literally have probably driven less than 100 miles since my last oil change and I definitely have no leaks which means I am burning it. This probably explains the tapping sound, but now I obviously have other core issues.
Truck: 302 with a c4 auto, holley 750 4160 carb (its too big everyone told me already)
History of my vehicle: The guy that I bought it from told me that when he bought the truck that owner had rebuilt the 302 in order to go racing. So he said the truck has about 5000 miles on it after rebuild. When I got the truck it was not tuned well, timing was off, choke had no power so it was running rich, valve cover leaks. I know the vehicle has roller cam and when I pulled the valve covers a long time ago the rockers paint looked worn? Maybe a junkyard rebuild? I'm not too familiar with the internals still learning.
I swapped the plugs, wires, set the timing, put power to the choke and adjusted the carb, new valve cover gaskets, new valve covers. I did a compression test about a month ago only dry it was between 109-119 on all cylinders (I feel like this is low). I will run another test tomorrow, dry and wet, and see what I find. I have white smoke coming of my exhausts at times, after I drive it around the block it usually stops (doesn't matter whether its hot or cold out) and exhausts smell like fuel until i drive it around the block
I run 10w-30 conventional and I also recently saw a video about Engine Restore from ProjectFarm on youtube. It seemed to work for him but I will do a compression test first to see the results. I will top off the oil and post an update with the compression results.
Format: Cylinder - Dry : Wet
1 - 111 : 120
2 - 126 : 113
3 - 113 : 105
4 - 119 : 108
5 - 107 : 124
6 - 113 : 119
7 - 115 : 139
8 - 124 : 116
I thought when squirting oil you could only go up in compression but I have no idea what these results mean. I did cylinder 2 twice again after noticing the drop and got 111 (no squirt) and then 113 with a squirt of oil, note that this was directly after the first wet - so results may be off.
Vacuum was reading about 15 at 14 degrees timing, I brought that to 13 degrees and then adjusted my air/fuel mixture screws to get vacuum up to 17.
After doing my compression test I let the truck run for about 20 minutes and the metallic noise pretty much stopped. It was extremely minimal and would only be able to hear it slightly at 3500+ rpm. Then I let the motor cool down for an hour started her up again to pull her in the garage and the full on metallic sound came back. No idea what to make of it it was 54 degrees all day.
So confused. I just want to drive my truck haha. Appreciate all the help guys.
Don't be intimidated by pulling the motor. First, drain radiator and remove. Remove battery. Remove headlights and buckets. Take horn relay, starter solenoid and voltage regulator off sheet metal, leaving wiring connected. Undo ALL wiring from inner fenders and snake back the headlight connectors (marker lights disconnect).
Leave hood on.
Get at least 2 friends that can lift. Take off 12 bolts - 3 horizontal bolts running just behind hood hinges (not the ones on the firewall), 1 bolt in underside of fender and one holding inner fender to isolator that goes to firewall (just above frame), and 1 on the core support. Repeat for other side, 12 bolts total. Lift finders, core support, grill, hood and inner fenders off as one unit.
Set aside.
Now pulling your motor does not look so daunting or back breaking. You will most likely find something in the bottom end of engine, but regardless you will want to pull it to work on it. Just way easier...
