What is the biggest tire I can fit on my truck(1995 4X4 15x7.5 wheels) with no rubbing I was thinking about 31s what do you
think???
P.S do not what a decrease M.P.G
You can actually fit 32x11.5x15 tire on your truck and on the factory rims without having to install a lift, you may notice a slight decrease in MPG and speed, but that depends on what gear ratio and how heavy your foot is.
Originally posted by kjett You can actually fit 32x11.5x15 tire on your truck and on the factory rims without having to install a lift, you may notice a slight decrease in MPG and speed, but that depends on what gear ratio and how heavy your foot is.
Man !! You are GOOOOOOOD !!
I would have had to at least ask what kind of truck he had.
Well, I didn't have to as yoda already listed that he has a 1995 4x4 with 15x7.5" rims , i.e. F-150 4x4 (by the way is the same year and type truck that I have, so I do know what fits without a lift (I have already been down that road)
A 32" tire will rub on the radius arm when you turn the wheel all the way. I have a picture of a stock F-150 with 32's on it in my gallery if you want to take a look. 1-2" is easy, just swap out the coil springs that cost about 130-140 bucks and get an alignment.
MustangGT221 is right, my bad . Just about anything over stock will rub on the radius arm. I just got used to not turning the wheel all the way. Or you can get creative with a bolt and make some stops, like the older solids have.
