Side View Mirrors
Old Feb 24, 2020 | 10:18 AM
DVUS's Avatar
DVUS
Question Side View Mirrors
Ok, probably dumb question ("there are no dumb questions, only the people that ask them") but here it goes.
I have a 2019 F250 XL CC 4x4.
It does not have the tow view mirror spot lights, but it looks like the bulbs are present in the mirrors (but hard to tell, the clear lens is there between the amber marker lights at least).
Does anyone know if the mirrors come pre-wired but minus the activation switch above the light switch?
If they are pre-wired, has anyone tried wiring it up to an upfitter switch?
Thanks!
Old Feb 24, 2020 | 08:57 PM
markusarealuis's Avatar
markusarealuis
Thanks!
i have experience with this, no the spot lights are not in those mirrors. It is a difference housing from the factory if your truck has spot light from factory. I attempted adding them to my truck 2019 F250 STX. I bought the switch, the module under steering wheel, bezel, and activated spot lights in Forscan. All completely functioning properly minus the actual spot lights turning on. After further research, you need the side mirror light that includes the spot. Two very different part numbers. I have since decided to buy the recon side mirror lights with spot lights included since the factory mirror lights would have been ~$260 and recon leds w/spots were $189 shipped to my house. Plus my side mirror lights had condensation in them anyways, otherwise it would not be worth the total cost of adding them (38 bezel, $13 switch, $113 module, $260 factory mirror lights w/spots) = $424 lol .... all that to say mine will end up costing me $353 still not worth it but I had gone too far already lol
Old Feb 24, 2020 | 09:04 PM
markusarealuis
I do believe the wiring is all there for spot lights, at least the wiring for my switch and spot light module were indeed there. I will know for sure when I replace the mirror lights with my Recons, I suspect there is a dummy plug sitting there behind the mirror lights not being used currently and I bet it is plug and play with recon lights since I have already added all the other stuff. If not, I will be SOL and just have a truck that appears to have spot lights but does not lol ....
Old Mar 9, 2020 | 10:00 AM
DVUS's Avatar
DVUS
Thanks you all, appreciate it.
Gianni
Aug 17, 2017 02:00 PM
Ron94150
Nov 9, 2016 06:26 PM
tjc transport
Feb 12, 2010 03:36 PM
surveyguy
Apr 19, 2009 09:16 AM
zstyle01
15
Nov 21, 2006 06:35 PM
