Truck bed
Old Feb 23, 2020 | 12:46 PM
HVFDFIREFIGHTER1618's Avatar
HVFDFIREFIGHTER1618
Truck bed
I have 4x4 pressure treated lumber for cross members above the two rails. I am going to use 2x8 red oak for the actual bed. Should I bolt those directly on the 4x4 or should I bolt 2” angle iron onto the side of the 4x4 and then bolt the floor boards to angle iron?
DoI need to use galvanized bolts going through pressure treated or can I use stainless steel?
Old Feb 23, 2020 | 02:04 PM
Mixer man's Avatar
Mixer man
Do I need to use galvanized bolts going through pressure treated or can I use stainless steel?
I would through-bolt the decking to the cross members using stainless carriage bolts because they look nicer and will take a polish better. Galvanized will also work with P/T wood. Don't forget to double nut. You can also go the galvanized angle iron route, just more work, no real advantage. What size bolts were you intending to use? When you lay down the 4x4 cross members try to keep the grain vertical.
Old Feb 23, 2020 | 02:27 PM
HVFDFIREFIGHTER1618
5/16 or 3/8, two per board every 2’
Old Feb 23, 2020 | 02:32 PM
52 Merc's Avatar
52 Merc
Is this truck bed going to be exposed to the elements or kept in a garage? Why use pressure treated lumber? If it will be able to primarily stay dry, conventional lumber will outlast us and you won't have to deal with the corrosive issues of PT lumber. Personally, it would not be my choice.
Old Feb 23, 2020 | 02:56 PM
Mixer man's Avatar
Mixer man
3/8" will be fine. I would also seriously consider what Wayne says, but I'd still go with stainless and polish the heads.
Old Feb 23, 2020 | 04:17 PM
HVFDFIREFIGHTER1618
What if I use 2” aluminum angle and stainless bolts?
Do the two metals play nice with each other?
Old Feb 23, 2020 | 04:23 PM
Mixer man's Avatar
Mixer man
316 stainless and 6061 aluminum play nicely together, however, aluminum and P/T wood don't like each other very much because the copper used in P/T wood is more noble than aluminum on the galvanic scale, and causes the aluminum to become sacrificial.
jniolon
38
Nov 16, 2017 12:12 PM
cbakker
2004 - 2008 F150
Jun 15, 2017 01:05 PM
jerryst
May 10, 2016 08:35 AM
Behemoth
13
Aug 24, 2008 11:55 PM
SethOveson
Sep 22, 2004 11:43 AM
