mounting and driling bed bolt holes - Ford Truck Enthusiasts Forums
Old 04-30-2016, 08:27 PM
jerryst
jerryst is offline
jerryst is starting off with a positive reputation.
How do you drill the bed bolt holes next to the side beds. Any tips or tricks to doing this? I have a 1955 ford f100.
Thanks
Jerry
Old 04-30-2016, 08:50 PM
56panelford's Avatar
56panelford
56panelford is online now
Posting Legend
56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation
I placed the boards in place and marked and center punched them then drilled them out on my drill press using a Forstner bit to get clean crisp holes without wandering..
Old 04-30-2016, 09:10 PM
jerryst
jerryst is offline
Hi 56panelford. I was thinking the same way. My idea was to place a strap around the sides. Also using a level until both sides are straight. But my question is the bolt opening on the bed has a square pattern for carriage bolts. Should I use carriage bolts or bolt with a mushroom head?
Jerry
Old 04-30-2016, 09:33 PM
56panelford
Posting Legend
My kit came with polished stainless steel carriage bolts Jerry. You could likely use the button head bolts but the carriage would make it easier to tighten the nuts from underneath unless you have someone to help you..
Old 05-01-2016, 03:47 PM
jerryst
jerryst is offline
I have carriage bolts. But my question is how do you allow for square part of carriage bolt into the wood?
Old 05-01-2016, 05:27 PM
Smitty49's Avatar
Smitty49
Smitty49 is offline
Smitty49 has a very good reputation on FTE.Smitty49 has a very good reputation on FTE.Smitty49 has a very good reputation on FTE.Smitty49 has a very good reputation on FTE.
Use a Mortising bit in the drill press.
Old 05-01-2016, 06:09 PM
56panelford
Posting Legend
You drill 3/8" holes for the side boards, the bolts are 5/16". The square under the head of the bolt barely touches the wood. All other bolt go between the boards through the skid strips.
Old 05-01-2016, 08:24 PM
CBeav's Avatar
CBeav
CBeav is online now
CBeav has a great reputation on FTE.CBeav has a great reputation on FTE.CBeav has a great reputation on FTE.CBeav has a great reputation on FTE.CBeav has a great reputation on FTE.CBeav has a great reputation on FTE.
Or you just drill the appropriate size hole and use a regular chisel to trim the upper edges square. Or begin each hole with a 3/8" bit to about an 1/8" deep then finish with a 5/16" bit. If you make the hole big and deep then the sheet metal gets bent as it's pulled into the hole by the bolt.
Old 05-01-2016, 08:27 PM
56panelford
Posting Legend
You drill them out 3/8 all the way so you have a bit of wiggle room and don't worry about the squared section of the bolt..
Old 05-01-2016, 08:52 PM
abe's Avatar
abe
abe is online now
abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.
Or you can buy one of those new square hole bits at Harbor Freight.
Old 05-10-2016, 01:01 AM
jerryst
jerryst is offline
wil drill out holes with a 3/8 drill.
Thanks
Jerry
Old 05-10-2016, 08:11 AM
jvmcc's Avatar
jvmcc
jvmcc is offline
jvmcc has a great reputation on FTE.jvmcc has a great reputation on FTE.jvmcc has a great reputation on FTE.jvmcc has a great reputation on FTE.jvmcc has a great reputation on FTE.
You do not have to make any special allowances for the square shoulder of the carriage bolt. First off, the holes that you drill for the side-most bolts should be a tad bigger than the 5/16 bolt shaft. I forget what I used, but it was probably at least 21/64" or 11/32". The square shoulder on the carriage bolts will fit into these holes.
Old 05-10-2016, 08:35 AM
abe's Avatar
abe
abe is online now
I drilled mine out with the same size bit as the bolt, I am not sure of the size. Then I putnpaint in the holemto protect the wood. Two nights ago I started to put the bed boards in place. The holes in the boards lined up with the holes in the side panels, except one was a little bit off. I could not get the bolts in place! So I drilled the holes bigger. About the paint? I said screw it, the two end boards were pressure treated and I have been messing with this bed so long I put the bolts in with out paint in the holes!
Boomer23059
Fifth Wheel & Gooseneck RV Towing
13
07-07-2017 01:56 PM
jimzpsd
2017+ Super Duty
03-04-2017 09:35 AM
blairsie
02-06-2017 06:50 PM
Chevmn56
02-04-2017 09:23 PM
408 Torquer
09-29-2016 04:34 PM
Quick Reply: mounting and driling bed bolt holes
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
