FMX
Old Feb 23, 2020 | 10:21 AM
waltmm's Avatar
waltmm
FMX
Looking for some help, I have a 1977 FMX with a tag number of PHC-A3, does anyone know the difference between a A, A1, A2, A3 , I can find what the applications are but not sure of what is different about them, after the PHC-A3 on my tag it has L 2 B is this November 2nd? and what would the "b" be? and Below that is says D7TP and I know what that is, but what would be the AGA that is after that? If someone has a PHC-A3 I would certainly be interested, thanks in advance for the help....
Old Feb 23, 2020 | 10:44 AM
KULTULZ's Avatar
KULTULZ
Post
The TAG INFO ensures one gets into the CORRECT PARTS LIST in the MPC. It also ID's the TRANS so one can find the correct SPECIFICATION LIST/repair procedures in the TRANS SHOP MANUAL.
Old Feb 23, 2020 | 11:30 AM
waltmm's Avatar
waltmm
thank you, I know what the tag is, but wondering what the difference is between the a,a1,a2,a3
Old Feb 23, 2020 | 12:14 PM
KULTULZ's Avatar
KULTULZ
Post
That is determined on how the TRANS was assembled and any upgrades through it's service life. You would have to go through the PARTS LIST/SERVICE SPEC LIST to see why and how. The APPLICATION CHART will give you usage for different applications. A1, A2 etc. is either describing possible service upgrades and/or application.
This trans was popular in the HP days and things like shift kits were readily available.
Do you have an APPLICATION CHART?
Old Feb 23, 2020 | 12:18 PM
waltmm's Avatar
waltmm
yes I have the application chart, what I am trying to figure out is what the difference was between the several modifications. looking for some more detailed info, I can not find the information that I am looking for
Old Feb 23, 2020 | 06:13 PM
KULTULZ's Avatar
KULTULZ
I don't know of any TECH MATERIALS printed on the FMX. Performance trans of the period were C4 and C6. The FMX was interim as FORD could not produce enough C4 or C6 to keep up with assembly. The FMX was heavier but had less internal drag as the C6.
The top performer was the later production C4 for the street and/or strip. The FMX seemed to have more favor with the Y-BLOCK crowd as it was an update over the FOM and COM.
Everything you want is in the MPC, WSM and TSB's of the era. I had one behind a 351CJ and it took years of abuse.
Old Feb 23, 2020 | 06:27 PM
waltmm's Avatar
waltmm
yes I am digging into that now, what I do know is that the FMX PHC-A was in 73 P350/500 the PHC-A1 was in 73-74 P350/500 , the PHC-A2 was in 74-76 P350/500 and the PHC-A3 was in 77 P500 and from what it seems all with the 300CI
Old Feb 24, 2020 | 05:28 AM
KULTULZ's Avatar
KULTULZ
Question
Did you see this ILL in the MPC ILL SECT? Maybe it will help explain what you are looking for. The TAG ID shows the trans is for a 1977 P-SERIES with a 300 CID.
Old Feb 24, 2020 | 07:32 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
OP has the same post in the LARGE TRUCK forum, so he knows what the PHC-A3 TRANS is for.
What he wants to know is what's the difference between the PHC-A1 & A2 transmissions. Probably nothing.
Old Feb 24, 2020 | 08:38 AM
KULTULZ's Avatar
KULTULZ
Question
Yeah, I saw that. I think he is wanting to know the internal design progression(s) done in each succeeding model year.
To do that, one would have to go through the correct PL and see what parts were upgraded through the years. Then I read he wants to modify a trans.
Old Feb 24, 2020 | 08:44 AM
NumberDummy
If you wanna look thru the catalog at every part, be my guess. I'm gonna pass!
Old Feb 24, 2020 | 12:19 PM
KULTULZ's Avatar
KULTULZ
Post
I think he inferred he has the catalog. I am just not sure what he wants to do.
Old Feb 24, 2020 | 05:19 PM
waltmm's Avatar
waltmm
yes I have found that, still doesn't explain me the difference, but I keep finding bits of information
MPoulson
Aug 21, 2024 03:02 PM
tree works
Large Truck
Jan 29, 2013 07:51 AM
SUPERDUTY OUTLAW
Mar 7, 2009 07:48 PM
HardFordCore
Dec 11, 2005 02:29 PM
