1966 Style side Bed
Old Feb 22, 2020 | 09:29 PM
konnor1's Avatar
konnor1
1966 Style side Bed
Hello I’m still looking around at trucks and went to look at a 1966 long bed today. Everything from the front of the truck up to the bed looked fine. Then there was the bed. On the left everything was fine and straight but on the right side there was quite a big hole. I wanted to know about how much it would cost to fix a rust hole of this size? Rough estimates $$? Are there other panels made to replace the outside of a style side bed?
Old Feb 22, 2020 | 09:34 PM
lewiscrouse's Avatar
lewiscrouse
Can't see the picture. How big is the hole?
Old Feb 22, 2020 | 09:39 PM
konnor1's Avatar
konnor1
Sorry I didn’t post a picture purely out of respect for the current owner(since I only have looked at the truck and not purchased). I have only went to look at it today, it’s about 8ish inches wide by 4in tall
Old Feb 22, 2020 | 09:50 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1964/66 F100/250 2WD & 1966 F100 4WD use the same 8' Styleside bed.
Old Feb 22, 2020 | 10:22 PM
konnor1's Avatar
konnor1
Any ideas on how much it would cost to repair?
or where to get new panels
just thought about this: maybe it’s called the quarter panel? Idk too much about the names of truck parts (more familiar with cars)
Old Feb 22, 2020 | 10:39 PM
Christmas's Avatar
Christmas
Everything on the west coast cost 3x more, so hard to say.
Old Feb 23, 2020 | 07:20 AM
konnor1's Avatar
konnor1
Okay that makes sense, so then scratch that question. Is there any replacement bedside panels?
Old Feb 23, 2020 | 08:05 AM
g4g2g7's Avatar
g4g2g7
if there’s an 8”x4” rust hole in the side of the bed, I think you need to give the rest of the truck a better look. More than likely that the rest of it is rusted worse than you think. Did you get underneath and look at the front cab mounts, cab corners, underside of the bed, bottom portion of radiator support, roof above the drip rails, etc? You’d be well served to get some pics and post ‘em here for folks to help guide you.
Old Feb 23, 2020 | 11:29 AM
konnor1's Avatar
konnor1
I did in fact check all that and it all seemed in very good condition. Nothing was rusted through from the front bumper to the back of the cab. The only issue is the driver fender is dented so that would have to be fixed but I don’t see that as a major issue. Cab mounts, radiator support was all good too.
I find it odd that it’s just on the one side of the bed but from what I saw everything looked just fine and has a little surface rust.
the only picture I have are from the online listing and they aren’t that clear, but I’ll get them up
Old Feb 23, 2020 | 11:57 AM
konnor1's Avatar
konnor1
Old Feb 23, 2020 | 06:27 PM
53deere's Avatar
53deere
There are no new or reproduction panels available for the sides of the bed but a relatively small 4" x 8" hole should not be that big of a deal to repair. If that is the only rust repair on the entire truck count yourself lucky.
Old Feb 23, 2020 | 06:30 PM
konnor1's Avatar
konnor1
It in fact is aside from the 1/4in plugged holes in the roof (used to have antenna) that’s the only holes, I think I may go ahead and get it, but that’s if I get everything settled with insurance, so if it happens I will post pictures
Old Feb 25, 2020 | 09:23 PM
James_Western_Canada's Avatar
Konnor: Is it possible the truck had an auxiliary fuel tank, which was later removed, and the hole is where the filler neck was?
But as far as how much would it cost to fix, I would not be able to put an accurate number to it without at least a picture.
The location of the hole plays a big part in the amount of work involved. (ie: how much access to the back, how much contour in the area of the hole, etc)
James
willholl79
30
May 12, 2018 09:21 PM
Baby Boomer
Ford Truck Parts for Sale
Apr 22, 2017 07:21 AM
ericford1984
Oct 23, 2011 07:37 PM
Ziegelsteinfaust
Mar 30, 2011 10:26 PM
charleenkay
Paint & Bodywork
Oct 10, 2004 04:18 PM
