Sync screen goes black
Old Feb 22, 2020 | 09:04 PM
edjunior's Avatar
edjunior
Hullo all. Shortly after I hit the road for some running around this morning, actually about a block from home, my Sync 3.4 screen went black. The radio was still playing, but nothing else worked, except the volume. I couldn't change stations, couldn't change media, nothing. It was just a black screen. I couldn't even turn it off or on. Since I was still in my neighborhood, I pulled over and shut the truck down so it would shut the radio off. Well, the radio kept playing, even with the key out, and I opened the door. After about a minute or so, it did finally shut down. I restarted the truck, and everything worked fine. And is still working fine. I'm not too worried yet, but could this be the start of the radio failing. I've read a few posts, but can't remember this specific issue being one. Suggestions welcome, but hopefully this is just a one time deal.
Old Feb 22, 2020 | 10:08 PM
Woody2010's Avatar
Woody2010
We had a similar issue in our 2016 Edge and after a few trips to the dealer then finally figured out it was the computer. I forget what it was exactly called. They first said it just needed to be rebooted but it kept getting worse and they finally did a more thorough test.
Old Feb 22, 2020 | 10:46 PM
ford390gashog's Avatar
ford390gashog
Add this to the list of failed APIM modules...
Old Feb 22, 2020 | 10:50 PM
ForCal's Avatar
ForCal
It did it on mine once, several months ago. At that time I tried turning the truck off and back on several times, but still black. It wasn't till after the truck sat off for maybe 30 min. that it returned to normal.
Old Feb 23, 2020 | 12:06 PM
GABAR's Avatar
GABAR
Sounds like a glitch in the SYNC system.
It should clear up on it’s own but if not, you should have the APIM checked by your dealer and yes, the system has to be acting up when you take it in.
Old Feb 23, 2020 | 06:24 PM
edjunior's Avatar
edjunior
I had the truck out several times today, and no black screen. I'll keep my fingers crossed and hope for the best, but be prepared for the worst.
jpmurray57
2015 - 2020 F150
Mar 13, 2018 11:40 PM
Brian Ensor
May 5, 2015 07:33 PM
ScaldedDog
25
Apr 27, 2014 08:49 PM
ron01sd
Apr 28, 2008 09:15 AM
fishfiles
Jan 13, 2007 12:20 PM
