Loosing Fuel Pressure
Old Feb 22, 2020 | 08:17 PM
Skyline Drive's Avatar
Skyline Drive
I added a Schradar valve to the back of the fuel bowl to check FP. When I turn the key on I hear the pump. The pressure rises to 52 psi, pump shuts off, holds pressure for 5 seconds then pressure drops to 30 psi. Is this a symptom of a faulty FPR or something else? I didn't see any leaks. The truck is a 99 with 48k miles and all original. Truck did sit for about 2 years with out starting and of course ran fine before. I also cleaned the fuel bowl.
Old Feb 23, 2020 | 12:14 AM
Wes444's Avatar
Wes444
Well according to my post filter gauge my pressure bleeds off completely as soon as the pump shuts off while I'm giving the glow plugs time to heat up before i crank er over
Old Feb 23, 2020 | 12:18 AM
'88 E-350's Avatar
'88 E-350
Everything I've read indicates that it's normal for the pressure to drop off when the pump stops.
Old Feb 23, 2020 | 07:51 AM
SkySkiJason's Avatar
SkySkiJason
The pressure drops when the pump times out.
You really need to see pressure when driving to know if you’ve got a problem.
Old Feb 23, 2020 | 08:21 PM
RA101725's Avatar
RA101725
Banned
What does it get up to with the engine idling?
MN_Andy
Feb 24, 2017 12:00 AM
Absolute
Feb 12, 2016 12:39 PM
fast2174
Sep 17, 2010 12:12 PM
bscaff
1978 - 1996 Big Bronco
May 13, 2009 01:17 PM
mrgn_mtt
Jun 25, 2007 04:57 PM
