Mean Green Starter
Old Feb 18, 2020 | 08:23 PM
firedaniel's Avatar
firedaniel
Mean Green Starter
Just upgraded and put a Mean Green Starter on my 06 wow it spins fast! Truck starts very quickly. Impressed... Wasnt cheap but is worth it
DW
Old Feb 19, 2020 | 01:14 AM
Euroman's Avatar
Euroman
Does it drag the volts down more than the standard starter?
Old Feb 19, 2020 | 07:31 AM
TooManyToys.'s Avatar
TooManyToys.
Chris tested the amps, but I don’t think anyone has checked max volt drop.
Old Feb 19, 2020 | 08:04 AM
SmackDaddy's Avatar
SmackDaddy
I’ll test when I get mine running
Old Feb 19, 2020 | 08:09 AM
firedaniel's Avatar
firedaniel
I watched my volts on my scanguage and it dropped to 11 starting but it started so fast may not be a good test. I also run high end odyssey batteries and have upgraded the battery cables already. I. Was very impressed with it.
Old Feb 19, 2020 | 10:24 AM
TooManyToys.
In order to test you have to have a voltmeter that is capable of recording min volts, not just real-time. The real-time data is dampened by the display speed of the meter. I have one fluke that does, one that doesn't.
Old Feb 19, 2020 | 09:13 PM
firedaniel's Avatar
firedaniel
My fluke does but it’s just cold outside. The truck sat 2 days 40 degrees and raining. As soon as the glow plug light went off it fired in less than a second! Very impressed.
Old Feb 20, 2020 | 09:29 PM
Fuzzpuss's Avatar
Fuzzpuss
Sounds we have a new candidate for Mean Green testing, Jack!
Get the full story here: https://www.ford-trucks.com/forums/1...a-starter.html
Old Feb 20, 2020 | 09:36 PM
SmackDaddy's Avatar
SmackDaddy
That thread makes my head hurt. I just put the damn thing in and the truck starts quickly. Not hating on Jack’s testing, it’s great info...I’m just ready to hear mine turn over and run again soon!!!
FP did you end up keeping your MG starter?
Old Feb 20, 2020 | 10:02 PM
Fuzzpuss's Avatar
Fuzzpuss
I know what you mean, lol. I read through it last night when I saw this thread. And for the record, the testing done there was mine, with Jack's guidance of course.
I sent it back. I was pissed about all the false advertising claims, and underwhelmed with the starting speeds. Ed gave me a full refund and edited his product page with a pic of the actual starter and some modification of the description. I put the old 273k mile OE starter back in and I'm perfectly happy knowing my batteries will last a little longer. I hope to be shopping for a new Denso 6.0 unit after the truck gets studded.
Old Feb 20, 2020 | 10:12 PM
firedaniel's Avatar
firedaniel
I saw that post and geez some people have more time than I do! I run odyssey AGM batteries with upgraded cables and a Bosh alternator. Mine starts VERY quick. No difference I can tell in voltage drop. Oil pressure and RPMs are what is required to start this truck and it hits almost instantly. I was just impressed with how fast mine started.
Old Feb 20, 2020 | 10:35 PM
TooManyToys.
Time ......... is relative.
Chris went out of his way to doing things out of the ordinary. And if you look at work done on his truck he is very detailed.
Old Feb 20, 2020 | 10:37 PM
Fuzzpuss's Avatar
Fuzzpuss
Some people around here make time to learn and inform others. And if you pay attention you'll notice it's those types who have the best answers and suggestions when someone has a problem.
What are you using to measure battery voltage?
How long have you had your Bosch?
Old Feb 20, 2020 | 10:44 PM
firedaniel's Avatar
firedaniel
I agree they are probably smarter than me. I used a scanguage the same one I’ve had for years. Very little change probably because it starts so fast. The Bosh I’ve had for 3 yrs. it’s been fine
Old Feb 20, 2020 | 10:50 PM
SmackDaddy's Avatar
SmackDaddy
my stock starter must have been going bad because the MG started it quick. I know I mentioned it in that thread and post a video of it. It really cranks in half a second, no more rurrr rurrr rurrrr start.
