V10 Excursion Fuel Issues.
Old Feb 18, 2020 | 04:12 PM
Travis65&79's Avatar
Travis65&79
So, our 01 Excursion was running flawlessly before hand. Not an issue. As my mother was driving it had just shut off on her outside of town with no sign of failure beforehand. Then couldn't get it started after, so we had it towed home. Really not interested in replacing a fuel pump unless i have to. I've replaced fuses and the fuel pump relay, as well fuel filter (wasn't too bad but definitely was old.) No pressure in the rail before doing so with no prime sound from the pump. it does have a full tank however she says she gave it a shot of sea-foam 1-2 weeks ago. Beginning to suspect its the pump at this point. '01 V10 Excursion 2wd. Any other ideas would be appreciated.
Old Feb 19, 2020 | 12:35 PM
Bently_Coop's Avatar
Bently_Coop
Hit the bottom of the tank with a board or something to try and vibrate the pump, it may start working and tell you what you need.
Old Feb 19, 2020 | 02:51 PM
Markken's Avatar
Markken
KOEO no pressure at the rails... no sound of the pump turning on...
Check the voltage wires going to the pump, if power is good, pump puked most likely.
Disconnect the first fitting and stuff it into a gas can, turn the key on and if no flow, replacement time I would say.
uwaidye
Feb 21, 2020 07:09 AM
Khmann
Aug 11, 2019 07:35 PM
mooreswm
Modular V10 (6.8l)
Jul 27, 2015 06:16 PM
dreibyrd
Modular V10 (6.8l)
Dec 14, 2013 05:33 PM
fair67driver
Aug 21, 2013 05:20 PM
