Frame off 1948 F-2 build
#48
I just cut the original transmission mount bolts.
It's a real tight fit, but it works. I fit the motor to clear the steering box so it's pretty high and a little far forward.I suspect the cross member will have to be notched when I move to an AOD.
I don't know how the transmission bolts are supposed to be removed, there's rubber blocks on the underside that i couldn't motivate out. One hell of a bonding, however it's in there.
#49
Build update
Wow! I’m sorry I haven’t kept anyone in the loop. Been making progress. Rolling chassis is done, engine and tranny installed (after fabricating custom mount). Brake lines done. Drive line in. Milled out the walnut for the bed from a friend’s tree. Just needing to finish cab metal work and paint so we can hook things up. Test fit the new treads with fenders temporarily in place.
also included is my son’s little mishap with the angle grinder and subsequent visit to the ER. He’s ok. Coulda lost a thumb. Lessons learned.
#50
#53
Damage truck
33
11-18-2017 06:54 PM
midfifty
18
12-29-2014 02:24 PM
77FordDW
27
02-12-2012 10:23 PM
