transmission question
Old Feb 15, 2020 | 11:17 PM
gogereaver's Avatar
gogereaver
me again. my buddy's 87 6.9 4wd just blew up. not worth fixing the leaf springs are threw the bed the rust is so bad. but to the point it has a t19 transmission can i fit that on my 1989 7.3 2wd. my c6 is still good but it will be nice to do a conversion when it does fail. maybe even steal the 4wd parts.
to bad its not a dully i so would take that to.
Old Feb 15, 2020 | 11:26 PM
DarkOverCast's Avatar
DarkOverCast
It'll fit, but you'll wanna grab everything you can. If the wheelbase is the same drive shafts will work.
Essentially you'll need the trans, crossmember, pedal assembly, clutch hydraulics, transfer case, front axle and all the hangers ect
It's quite a bit of work. But I love my 4 speed and 4wd
Old Feb 16, 2020 | 09:45 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The 4x4 T19 will not fit in your 4x2 truck without converting the trans to two wheel drive or converting your truck to four wheel drive.
Old Feb 16, 2020 | 04:37 PM
gogereaver's Avatar
gogereaver
so whats the a matter of getting the proper driveshaft or adding the 4wd parts.
Old Feb 16, 2020 | 04:39 PM
ford390gashog's Avatar
ford390gashog
It will fit as long as the OP installs the transfercase. I have seen lots of trucks that were 4x2 and people had swapped trans and transfercase just for low gear reduction ability.
Old Feb 16, 2020 | 05:23 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
I think you need to sort out the Flywheel too.
LUK has one flywheel that is same PN for 6.9 and 7.3 but I would dig into it many Opinions say yes and no.
Old Feb 16, 2020 | 06:03 PM
DarkOverCast
I would absolutely recommend exactly this if you choose the t19 because in my opinion first gear is too damn tall. Especially for me with 33" tires and 3.55 gears outback
6.9's all had single mass flywheels, there may have been a dmf in the 87's that were offered with the 5 speeds but I know the 87 4 speeds has the same single my 85 has.
Unless the clutch looks rather new I'd replace it and have the flywheel turned too
DmanNC
25
Oct 4, 2014 04:50 PM
jad4
Jun 17, 2005 09:51 PM
79Ford460
Jul 9, 2004 03:29 PM
ofos
Jul 16, 2003 07:00 AM
