Modular V10 (6.8l)
Engine missing
Old Feb 15, 2020 | 09:18 PM
Moodyblues's Avatar
Moodyblues
Engine missing
2000 F250 V10
1. Replaced the plugs and coil packs with boots (motocraft)
After replacing these the truck ran great for about 60 miles and started missing again.
2. Replaced a coil pack harness. Replaced PVC.
3. Replaced the pvc hose into the intake.
4. Cylinder #3 previously had blown out a plug - about 3 years ago. I had put plug back in and it was fine until now. I just replaced with a dorman from the parts store.
I had previously taken to a mechanic and scanned. No codes. No dash lights.
Any suggestions are welcome.
Old Feb 15, 2020 | 11:14 PM
Bently_Coop's Avatar
Bently_Coop
Dorman spark plug?
I only run Motorcraft for mine. I also use Denso for the Coil packs.
Does your engine have the PCV elbow under the throttle body? Check it too.
Fuel Pressure check?
Old Feb 16, 2020 | 08:58 AM
Moodyblues's Avatar
Moodyblues
Originally Posted by Bently_Coop
Dorman spark plug?
yes Dorman plug it's the only one you can use I believe.
Yes the elbow and I replaced it.
No fuel pressure check.
odd thing is like I said it ran perfect after replacing the coil packs for 60 to 80 miles, then started same miss. No dash lights ever.
I am back to thinking a coil pack because it was fine for about 2 hrs driving and it was smooth.
Old Feb 16, 2020 | 10:37 AM
truckfella's Avatar
truckfella
Over on YouTube, FordTechMakuloco just did a video wherein he compared authentic Ford Motorcraft parts (plugs and coils) vs fakes/counterfeits. I am surprised (although I shouldn't be) to see the extent the Chinese will go to manufacture parts and packaging to replicate that of the real stuff.
Did you buy Motorcraft parts? If so, are you SURE you didn't receive fakes? That could be the problem...
Old Feb 16, 2020 | 02:25 PM
Moodyblues's Avatar
Moodyblues
That could be the problem. I bought the Rock Auto "Motocraft" coil packs. They were in Motocraft bags. There is no motorcraft on the coil pack itself.
Old Feb 16, 2020 | 10:35 PM
Moodyblues's Avatar
Moodyblues
so I pulled number 3 coil pack and that one is the problem. It is the cylinder I repaired with the dorman. The plug boot was burned half the way up. I replaced the boot and it continued to miss. There is no blow by with the dorman insert. I took another old motorcraft coil pack and it still misses.
Whew.
Old Feb 17, 2020 | 09:31 AM
truckfella's Avatar
truckfella
Can you explain why you can only use Dorman plug, as I've never heard of this before.
Personally, I would hesitate to put anything on any of my vehicles made by Dorman.
Old Feb 17, 2020 | 04:47 PM
Moodyblues's Avatar
Moodyblues
it was the only thing that I knew to purchase. It is made specifically for the V10 and a friend on mine has had one in his truck for 10 years.
Old Feb 17, 2020 | 05:35 PM
rock2610d's Avatar
rock2610d
A new plug boot burned half way up!!!
Your insert or plug is leaking.
idle may not show leak because throttle body is close and not much air can get into cylinders. Under more throttle with less vacuum more air comes in making cylinder pressures higher. So maybe it's leaking when motor is under a load.
Old Feb 17, 2020 | 05:45 PM
rock2610d's Avatar
rock2610d
I looked up the dorman spark plug repair kit.
it looks like they use an over sized adapter epoxid into stripped out hole. and a 3V v10 type spark plug.
what did you torque plugs to?
Old Feb 18, 2020 | 10:53 AM
RazorsEDGE's Avatar
RazorsEDGE
If it is the Dorman insert leaking then look into the Calvan or timesert repair kits. They will be a much better fix and you can use the correct plug.
Old Feb 18, 2020 | 05:31 PM
Moodyblues's Avatar
Moodyblues
Thanks. Having that done tomorrow.
Old Feb 19, 2020 | 12:52 PM
Moodyblues's Avatar
Moodyblues
did this morning and it fixed it. Thanks
Old Feb 19, 2020 | 02:22 PM
RazorsEDGE's Avatar
RazorsEDGE
Awesome.
Old Feb 20, 2020 | 04:39 AM
JWA's Avatar
JWA
Here's that video----its great and well worth watching it all the way through:
I recently bought quite a few COP's through Amazon and wondered if I'd received the right stuff--turns out I did. By sheer luck I'd bought from one of the seller's Brian cites as being trustworthy.
Watching that video will show if your COP's are real or fakes.
