Sponsored by: Real Truck
front suspension help!!!
Old Feb 14, 2020 | 09:33 PM
Gil7.3's Avatar
Gil7.3
Exclamation front suspension help!!!
I have completely rebuilt the front suspension and steering of my 2002 f-250 7.3 4x4. Yet i still get popping sound when I turn my truck on and the first movement I do either turn left or right I get the popping sound (feels like it comes from the driver side). I don't know if its from my U-joint from axle shaft, steering pump, or steering wheel column. My steering wheel also squeaks when I turn. I also started to get a humming noise from 10mph -40mph. Any advice would help Thank you.
This is a list of all new parts
  • Front Lower Ball Joints
  • Front Upper Ball Joints
  • Front Tie Rod End at Pitman Arm
  • Front Tie Rod End at Right Hand Connecting Tie Rod
  • Front Outer Connecting Tie Rod End Passenger Side
  • Front Outer Tie Rod End Drivers Side
  • Tie Rod End Adjusting Sleeve at Pitman Arm
  • Tie Rod End Adjusting Sleeve Driver Side
  • pro comp 2 inch leveling leaf springs
  • zone adjustable track bar
  • wheel hub assembly
  • all new u joints on my front drive shaft
Old Feb 14, 2020 | 11:32 PM
Yoteman's Avatar
Yoteman
You need to get someone under the truck watching to see where the pop comes from when you turn the wheel . Take the guess work out of it.
Old Feb 14, 2020 | 11:48 PM
LJForrist's Avatar
LJForrist
Agree that having someone down to look at it while moving would be a big help. One thing you might check on is the bushings in the spring hangers. When mine went bad it was more of a clunk than a pop, but at least one more thing to rule out.
Old Feb 16, 2020 | 12:32 PM
Djosbun's Avatar
Djosbun
So when you START the truck, still in PARK, you get a popping sound? Is it a 4x4, where you might have a vacuum leak? Have you checked the motor mount on that side?
-- Dave
Old Feb 17, 2020 | 01:49 PM
Byrd.Dog's Avatar
Byrd.Dog
I experienced a similar situation & mine ended up being a wheel bearing going out.
Anthony Polsinelli
17
Apr 7, 2024 09:15 PM
countryboy73703
6.4L Power Stroke Diesel
13
Sep 12, 2013 09:31 AM
snickersandapepsi
Aug 14, 2010 04:30 PM
jplinville
Mar 23, 2010 07:39 PM
alberta46
1997 - 2003 F150
Sep 29, 2009 09:58 PM
