Best tie rod ends? Which is Which?
I am confused as hell on which tie rod ends i need. I can take the truck apart and rebuild it from the ground up, but do not know what the parts are all called haha
I need both tie rod ends that run from the pitman arm down to the other tie rod that connects the 2 steering knuckles.
I was told to get moog by a friend, but did some research and am finding that they have lost some of their quality?
What would the best tie rod ends be? Yes i know this will probably be an opinion thing but there has to be a relatively common one..
Mon-Fri 8am-6pm
Support
Login
Cart (0)
Moog Suspension Parts
Home
Products
Search
Cart
MOOG MOOG_PACKAGEDEAL012 Front End Steering Pack
Moog_PackageDeal012 Front End Steering Pack
Manufacturer: MOOG
Part Number: Moog_PackageDeal012
Rating 11
Purchase
$686.55 - 5% Off Moog Package Deals - Save: $34.33
Price: $652.22
Free Shipping! In Stock Ships Immediately
In The Box of moog_packagedeal012
Suggested Parts 1
Warranty Information
Ask us a Question
Details
Front End Steering Package Kit
A Package Deal that includes all the main steering parts for your vehicle made by Moog
Ford F250/F350 Super Duty 4WD 1999-2004
Includes:
•Front Lower Ball Joints - (Quantity 2)
•Front Upper Ball Joints - (Quantity 2)
•Front Tie Rod End at Pitman Arm - (Quantity 1)
•Front Tie Rod End at Right Hand Connecting Tie Rod - (Quantity 1)
•Front Outer Connecting Tie Rod End Passenger Side - (Quantity 1)
•Front Outer Tie Rod End Drivers Side - (Quantity 1)
•Tie Rod End Adjusting Sleeve at Pitman Arm - (Quantity 1)
•Tie Rod End Adjusting Sleeve Driver Side - (Quantity 1)
Footnotes
•One Set Will Cover the Left and Right Side
Description
Reviews 11
Fitment
“ Replacing your OE parts with Moog's problem solver front end parts will give your Ford the performance and the dependability that you need.
Drew Taylor
Drew Taylor- DST Parts Guru
Moog Front End Steering Package Deal 012
Moog K80026
Frond end steering parts are vital to your suspension. If your truck is pulling, your tie rod end could be shot throwing of your alignment. If your front end is shaking or your steering wheel is loose, your ball joint might have failed. Identifying the correct ball joint alone can be a little tricky, so trying to find an entire steering package can be intimidating. But we here at Diverse Suspension Technologies, have taken the guesswork and difficulty out of the picture. This is Moog Package Deal 012: A complete front end steering pack for the Ford F250 and F350 SuperDuty from 1999-2004 4WD. If you have a 2WD Ford, we have a steering pack for you as well. For the Twin I Beam Axle there is 081 or for the Monobeam Axle there is 082. Replacing your OE parts with Moog's problem solver front end parts will give your Ford the performance and the dependability that you need.
Moog ES3423
Steering Parts Included
Moog Package Deal 012 has been created right here at DST and includes all of the front end steering parts for your Ford truck at a premium discount. Included in this kit are the front upper and lower ball joints for both the driver and passenger side. All four tie rods are included, along with the two tie rod end adjusting sleeves.
Moog K8607T
Moog's "Problem Solver" Ball Joints
The Problem Solver line is Moog's top line of parts. Through extensive research and engineering, these problem solver parts target factory original problems and provide a new part to outlast and outperform the OE part. Starting with the ball joints, we have the upper and lower ball joint for each side. Your ball joints are mounted in the control arm or spindle. Inside this part is a ball joint stud that swings to compensate for the up and down movement in your suspension. So your ball joint basically works simultaneously for the steering and suspension. Once your ball joint fails due to rust or factory defect, your truck will being to pull to either side, your steering wheel will have extra play, your front end will shake and your tires will wear prematurely and unevenly. So with all that being said, it is vital that you choose a replacement ball joint that is dependable. Moog's problem solver ball joints are just that, dependable.
Camaro Steering Linkage Designed to be greasable and using a hardened steel stud, these ball joints are both durable and easily servicable to ensure a long life. In addition to the increased durability, these ball joints use Moog's "gusher" bearing design, transferring vehicle loads through the ball joint and into the housing, reducing stress on the ball joint itself. Included with the ball joints are zerk grease fittings and neoprene dust boots to seal in grease and keep out harmful road contaminants.
Moog ES3427T
Tie Rod Ends
Also include in Package Deal 012 are all four tie rod ends you need. We have the front tie rod at the pitman arm, the tie rod end at the right hand connecting tie rod. Here is the front outer connecting tie rod for the passenger side, and the outer tie rod end for the driver side. The tie rod is a major pivot points in the steering system. Like the ball joints, the tie rod has a ball and socket design on one side that connects to the steering arm. When your steering wheel moves, this ball and socket allows the wheels to turn. With Moog's problem solver tie rod ends, you can ensure that your vehicle's steering ability is increased and stays dependable.
Moog ES3426S
Tie Rod Adjusting Sleeves
Lastly in the package are the two tie rod end adjusting sleeves, one on the driver side and one at the pitman arm. These sleeves are coated for corrosion resistance and are made of steel for durability. The adjusting sleeves join the tie rod ends to the steering linkage and allow your Ford to be aligned properly. All Moog Problem solver steering components are backed with a lifetime warranty handled in house at DST. If you have any questions be sure to give us a call or hit the live chat button.
Quick Links
•Car Parts
•Truck Parts
•Universal Parts
•Privacy Policy
•Frequently Asked Questions
•Parts Index
•Installation Instructions
•Dealer Inquiries
•Return Policy
Customer Comments
Your pricing and service was exceptional!...
Bob S
Contact Us
888-406-2330
Livechat Offline
888-406-2330
Sales@Moog-Suspension-Parts.com
2355 County Road 490
Stephenville, Texas 76401
Moog Trustmark
Moog-Suspension-Parts.com is Copyright ©2004-2015 Diverse Suspension Technologies. All Rights Reserved. Compliant Code
Mon-Fri 8am-6pm
Support
Login
Cart (0)
Home
Products
Search
Cart
Manufacturer: MOOG
Rating 11
Purchase
Price: $652.22
Suggested Parts 1
Ask us a Question
Details
Includes:
Footnotes
Description
Reviews 11
Fitment
Drew Taylor
Moog K80026
Moog ES3423
Moog K8607T
Moog ES3427T
Tie Rod Ends
Moog ES3426S
Quick Links
•Car Parts
•Truck Parts
•Universal Parts
•Privacy Policy
•Parts Index
•Dealer Inquiries
•Return Policy
Customer Comments
Bob S
Contact Us
888-406-2330
Livechat Offline
888-406-2330
Moog Trustmark
I went with these for my ball joints and tie rods
XRF Ford Truck Front End Kits | Front End Kits available from American Undercar
I put moog in the first time and they didn't last too long.
The following users liked this post:
The million mile warranty is a cool idea. Moog offers the lifetime warranty as well though
Only about 6 months so far but I have heard good reviews on them sounds like moog from what I have heard has kinda gone downhill but that's just hear say I know mine lasted about 3 years before they went bad ( ball joints ) my tie rod ends were still ok but figured to just do everything. I was going to go with moog again but after a search the XRF stuff had good reviews Moog was hit and miss.
I've had my XRFs for 22 months and 38K miles and still doing great.
Prior to that I had Moogs and they lasted 4 1/2 years and 66K miles. Not a bad life considering the amount of off-roading I do (when I took them out three of them were shot). I read some hit and miss comments when I was shopping around for more Moogs so I went the XRF route. I've been very happy with them.
When I rebuilt my front end I had did a lot of research and I found the only guys having issues with Moogs tie rod ends were guys that played off road and were running over sized tires. Now when it came to ball joints the Moog's weren't holding up even on stock trucks that only run on the street. So there are many different factors that can play a roll in how long a part can hold up.
My truck had 199k when I went to rebuild the front end and all tie rod ends and center link looked to be OEM but the ball joints had been replaced with Moogs and 3 out of 4 were bad. So I replaced all tie rods & center link with Moogs "Problem Solver" parts and I used XFR ball joints. I only have about 15k on the front end so I can't say how long they will last. But since I drive like an old man and do mostly highway miles I hope not to have an issue for at least 100k.
Fingers crossed !!
Fingers crossed !!
Their warranty is misleading. I replaced all the steering components with XRF a little over 2 years ago and the tie rod end is worn out. I called and they told me that those parts are not covered under warranty due to wear and tear, in 2 years there is not that much wear and tear on a ball and socket.
